75.5mm Headgasket with a 75mm bore? Does it matter? (cometic MLS)
I found a cheap cometic MLS 75.5mm headgasket and Im in a crunch for a gasket and saving money is good
but can I use a 75.5mm gasket when my bore is still the standard 75mm?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PanekMekanik »</TD></TR><TR><TD CLASS="quote">I found a cheap cometic MLS 75.5mm headgasket and Im in a crunch for a gasket and saving money is good
Thanks</TD></TR></TABLE>
it will work
its only .25 a side not much
it will work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRAN »</TD></TR><TR><TD CLASS="quote">
it will work
its only .25 a side not much</TD></TR></TABLE>
I don't know why most people don't understand this.
It's not a .5mm difference! It's .25mm - that's like a human hair.
it will work
I don't know why most people don't understand this.It's not a .5mm difference! It's .25mm - that's like a human hair.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">It's fine, it won't hurt anything and you're no more likely to blow it than if you had a 75.5mm bore. What motor has a 75mm bore?</TD></TR></TABLE>
d15/16
d15/16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed »</TD></TR><TR><TD CLASS="quote">
It's not a .5mm difference! It's .25mm - that's like a human hair. </TD></TR></TABLE>
Alot of people dont work in machine shops, I do so I know the difference is almost nothing, but I didnt know if it matterred
I don't know why most people don't understand this.It's not a .5mm difference! It's .25mm - that's like a human hair. </TD></TR></TABLE>
getgot22
Mar 27, 2006 06:28 PM
jt-sport
11
Feb 11, 2004 02:57 PM
