Best ECU for a B18B???????
hey hey..
im gettin a 94 civic with a B18B4 engine in about a month (yea they brought some out here in South Africa with B18B's already installed
so i was just wondering what the best ECU wud be to use with the B18B??? ie do i get it chipped/ piggyback/ standalone????
gonna be putting on cone air filter, and header and 2.25" exhaust shortly after i get the car... and im looking to do the ECU... i just dunno which one gives best mid/upper range power...
in the future i'l be doing flywheel and cam and valve springs too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rich990 »</TD></TR><TR><TD CLASS="quote">k well has anyone done an ECU with just exhaust an headers an filter?? </TD></TR></TABLE>
Its pointless. You're just dumping more fuel for maybe 1hsp. But do what you want
wait so if i understand this right, doin ecu wont realy have any effect if u havent done cams and stuff?? what all do i need to do to benefit from chipping??
sorry im such a nOOb...
u can chip a ecu to give u more fuel and a longer rev, but it is very pointless if your just using a intake exhaust and header, once u get DEEP inside then u will need it, head work or block work, just stick with the stock ECU
you could spends hundreds of dollors getting it chipped and tuned an maybe get like 5 hp.....or you could save the few hundred dollors and get a turbo kit...than you would need to chip/tune the ecu.....
if the motor is stock from valve cover the oil pan...than the ecu should be stock as well...end of story.
pr_tony_montana
20
Jun 20, 2016 07:18 AM
mistaashby12
11
Aug 4, 2008 07:46 PM
dkboyny11
Sep 11, 2007 11:30 AM
