Quick swap question
Old Mar 21, 2006 | 08:45 PM
D16y8_Rebuild's Avatar
Default Quick swap question
I have a 2000 civic ex and want to know what i would have to do to but the 2000si engine into my car i was thinking it was a direct bolt up but i still wanted to make sure. And if it isnt i would like to know all the steps i have to take and everything that has to be changed. Thx
Old Mar 21, 2006 | 08:48 PM
BlueIntegraBoy's Avatar
Default Re: Quick swap question (D16y8_Rebuild)
You need longblock, transmission, axles, shift linkage, ECU, rear transmission bracket, driver side block mount.
Old Mar 21, 2006 | 09:07 PM
and it well go right in and work then right
Old Mar 21, 2006 | 09:10 PM
how much is that engine anyway
Spracer03's Avatar
if you have ALL si parts it will directly bolt in.. just make sure you especially have the Si shift linkage and rear "T" Bracket aka torque bracket
Old Mar 21, 2006 | 09:11 PM
Spracer03's Avatar
ive said it a million times before... check hmotorsonline.com
Old Mar 21, 2006 | 09:15 PM
thx
Old Mar 21, 2006 | 09:18 PM
is there a better engine i can throw in for less
Old Mar 21, 2006 | 09:20 PM
Default Re: (D16y8_Rebuild)
Better than a B16, but for less? Nope. The next step is an LS, cheaper, but not better stock for stock.
Old Mar 22, 2006 | 02:50 PM
thx
Ha Itz
Nov 20, 2006 06:06 PM
swiftstyles
Dec 6, 2004 09:04 AM
Se-rv-Tak
Nov 29, 2003 11:59 AM
89JDMcrx
Nov 23, 2002 10:25 AM
DaiJekBok
Jul 21, 2002 04:31 PM
