the truth about the ZEX 59300 cam?
Old Mar 21, 2006 | 08:23 PM
mike93boost's Avatar
Default the truth about the ZEX 59300 cam?
okay, its suggested you upgrade springs and/or retainers with this cam. BUT, alot of people say you will be okay on stock springs and all as long as you dont go past redline. will this be okay or was this cam meant to rev past redline.
and how much would i benefit from using this cam on a boosted d16? any hp guesses?
Old Mar 21, 2006 | 08:37 PM
eh3 93's Avatar
Default Re: the truth about the ZEX 59300 cam? (mike93boost)
I'd like to know also.
Old Mar 22, 2006 | 12:33 AM
dcsports's Avatar
Default Re: the truth about the ZEX 59300 cam? (eh3 93)
search!
Old Mar 22, 2006 | 01:44 AM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">
and how much would i benefit from using this cam on a boosted d16?</TD></TR></TABLE>
Everyone and their mom uses that cam (including me). I wouldn't use anything else.
Old Mar 22, 2006 | 05:37 AM
USDM 4G VTEC's Avatar
as long as y stay 7500 or less, no need to upgrade springs and retainers
i have had this cam for a year and a half and works great under boost.. plenty tq on the power band
Old Mar 22, 2006 | 07:43 AM
I Have an STD's Avatar
wrenchin'
Default Re: (USDM 4G VTEC)
a couple local guys use it and use valve spring shims on stock valve springs and rev them to 8k rpm. not once have i heard of problems
Old Mar 22, 2006 | 09:17 AM
sounding good so far.. what about the gains, is it worth it?
Old Mar 22, 2006 | 12:20 PM
Soccerking3000's Avatar
Default Re: (mike93boost)
it is definately worth it, and yes you DON'T need to upgrade the valve springs/retainers with the cam although i suggest it. Furthermore if you plan on revving past 7800rpm then maybe the cam isnt for you thats when it stop making power. I have mine and love it, i do however rev to 9k but for what the cam lacks the turbo easily makes up
Old Mar 22, 2006 | 04:03 PM
Simple SOHC's Avatar
I'm guessing that if you upgrade the valvesprings...the cam will make power above about 7k RPM?...with the cam and stock springs you only make power to about 7k?
Old Mar 22, 2006 | 04:06 PM
Default Re: (Simple SOHC)
the springs/retainers dont add power they just allow you to rev higher thus using the full potential of the cam
Old Mar 22, 2006 | 04:26 PM
pip9's Avatar
Default Re: (Soccerking3000)
where did u all buy your zex cams from? i cant seem to find any sponsor's in the marketplace section selling them. Zex site has it for $283
Old Mar 22, 2006 | 05:29 PM
Default Re: (pip9)
ebay
Old Mar 22, 2006 | 07:39 PM
pip9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">ebay</TD></TR></TABLE>
i found one for $230 sounds like a decent price?
btw... i'll be runing this cam on stock springs/retainers to the stock redline
edit: i went ahead and bought the zex springs too.
Modified by pip9 at 11:54 AM 3/27/2006
Old Mar 22, 2006 | 07:43 PM
Default Re: (pip9)
you're good to go
Old Mar 22, 2006 | 07:45 PM
EX-T's Avatar
Default Re: the truth about the ZEX 59300 cam? (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">
Everyone and their mom uses that cam (including me). I wouldn't use anything else.</TD></TR></TABLE>
/\ I'm with him and I'm boosted!!!!!!
Old Mar 22, 2006 | 07:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">the springs/retainers dont add power they just allow you to rev higher thus using the full potential of the cam</TD></TR></TABLE>
Yeah...thats what I was tryin to get at. Since the cam makes power to ~7800...the springs will allow you to rev that high and get that power.
Old Mar 22, 2006 | 08:02 PM
platinum00's Avatar
the cam makes a nice difference in the top end.
you dont need to upgrade the spring/retainers if you stay around the stock rev limit.
but springs and retainers are cheap, just get them and enjoy the extra power band
platinum.
Old Mar 22, 2006 | 09:45 PM
will any tuning be necessary if you install this cam? like a/f or timing? or do you just drop it in and go?
Old Mar 23, 2006 | 05:00 AM
bluemax189's Avatar
definately a valve lash will be needed to be performed. the lobes on these are alot different that stock, so setting valve clearances is important.
Old Mar 23, 2006 | 09:18 AM
Default Re: (bluemax189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 &raquo;</TD></TR><TR><TD CLASS="quote">definately a valve lash will be needed to be performed. the lobes on these are alot different that stock, so setting valve clearances is important.</TD></TR></TABLE>
oh yea i know that. ill also set the timing.. but what about any forced induction tuning?
Old Mar 23, 2006 | 09:26 AM
if you are already boosted and tuned i would suggest a retune because i wouldnt be suprised if you gained 30+whp in the upper rpms from the cam, not to mention all the midrange gains
Old Mar 23, 2006 | 03:57 PM
CPRace_Hatch's Avatar
Going to use this cam in my Z6 build. Heard nothing but good reviews. I also got springs/retainers cause I plan to rev it to 7800+
Old Mar 25, 2006 | 02:39 PM
drintegra's Avatar
had the cam in my z6. I put the cam in when the car had 160XXX and now it has 220XXX stock springs and everytihng. I have the stock rev limit and I have had no issues. I never dynoed, but b4 the cam in a SI with full interior I ran 16flt after I ran 15.6 with a really bad clutch there it is.
Zex is the ****
Old Mar 25, 2006 | 09:38 PM
just ordered one. cant wait..
Old Mar 26, 2006 | 09:30 PM
is a cam gear needed with a aftermarket cam?
