Clunking noise when move stering wheel or drive over bumps...
I have a 94 Civic coupe, and I have a problem that I don't know what is....
Not to knowlaged on suspention, but, I recently bought ths car and noticed when the car is not movng I shift the steering wheel back and forth itll make a lcunking sound...
I assumed, and figured it was the tie rods. So I replaced them all both inners and outters.
clunking still appears....
Itll clunk over bumps when driving....
I though it was my struts( coilovers slammed, struts=no fluid left in them, totally blown)
but I kinda think it may be the steering rack (manual)
what is your opinion/fact?
is there a way to test to see where the problem is?
I also thoght it may be the steering rack , bushing?
steering knuckle balljoint?
well, this is right off the top of my head. Not sure if I'm correct but. when you turn the wheel the suspension flexes. It could be the coil overs poppinf on the blown struts.
It sounds like you need to replace the suspension anyways. So do that and see if the problem still occurs.
damn im an idito, I foregot I didnt replace the driver side outter tie rod end...
But keep your opinions coming if this doesnt fix the problem... cuz the tie rod boot looks perfect...
Big1000
10
Dec 5, 2018 02:10 PM
