Is it impossible to put a K20A in a 1996 Integra GSR?
Old Mar 21, 2006 | 06:07 PM
JBirch_97Prelude's Avatar
Default Is it impossible to put a K20A in a 1996 Integra GSR?
I am thinking of doing a Engine swap, from a B18 to K20A is it impossible?
Old Mar 21, 2006 | 09:55 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Is it impossible to put a K20A in a 1996 Integra GSR? (RippleSound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RippleSound &raquo;</TD></TR><TR><TD CLASS="quote">I am thinking of doing a Engine swap, from a B18 to K20A is it impossible?</TD></TR></TABLE>
Nope, just expensive. They make mount kits, linkage kits and wire-harnesses to make this a "bolt-in" affair. Not an easy task, but yes its very possible and has been done.
Old Mar 21, 2006 | 11:22 PM
Boostage's Avatar
My only reason for being against a K swap is because you cant have a/c and that a must in FL. if u ever get stuck in bumper to bumper traffic when its 90 degrees out its the worse feeleing ever.
Old Mar 22, 2006 | 10:28 AM
aspec101's Avatar
Default Re: (Boostage)
check out k20a.org for all the info you need. Also you can retain your a/c and powersteering with the swap. Of course custom lines are in order for that. anyways go check out the site excellent k20 source.
Old Mar 22, 2006 | 12:25 PM
Boostage's Avatar
Default Re: (aspec101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aspec101 &raquo;</TD></TR><TR><TD CLASS="quote">check out k20a.org for all the info you need. Also you can retain your a/c and powersteering with the swap. Of course custom lines are in order for that. anyways go check out the site excellent k20 source.</TD></TR></TABLE>
HondaTeKnology
Dec 9, 2007 04:28 PM
Kentagious
Nov 21, 2007 03:17 PM
p1ccoloz
Dec 29, 2006 03:09 PM
crawdaddy169
15
May 13, 2005 09:29 PM
87hondacivic
21
Apr 21, 2004 01:00 PM
