HELP! steering wheel moves back and forth bad!
Old Mar 21, 2006 | 03:37 PM
jochute@hotmail.com's Avatar
Default HELP! steering wheel moves back and forth bad!
92 accord 4dr lx the steering wheel moves back and forth no matter what speed you are going it is getting real annoying. I like the car so I put a new steering rack in with new tie rod ends and an alignment, but no change at all. I have new lower ball joints to put in and I think that I am going to buy new upper ones w/ the control arm, but could this do the trick or could it be something else. I really like tha car a lot as my second car so iwould like to get it where I enoy driving it thanx josh
Old Mar 21, 2006 | 03:48 PM
93.2's Avatar
Default Re: HELP! steering wheel moves back and forth bad! (jochute@hotmail.com)
tie rod ends? i had this in my van bad like a ****... nothing like unwanted lane changes on teh highway
Old Mar 21, 2006 | 04:40 PM
P_Adams's Avatar
If this condition happens at slow speed, the steering wheel oscillates back and forth and doesn't get worst when you apply the brakes, you most likely have a broken belt in either one or both of the front tires.
This can be spotted with an educated eye and a set of jacks.
Raise the front of the car and let the tires hang.
Start the engine and put it into low/first, let the front wheels spin.
If you've got a broken belt, you'll be treated to some pretty strange tread movements (if often shifts from side to side as the bad spot passes)
P
Old Mar 21, 2006 | 04:51 PM
that may be it bc the tires arent in the greatest shape on the front and it doesnt get worse with braking so I will check it out. I have never had this problem out of all the cars that I have owned. thanx for the reply
Old Mar 21, 2006 | 04:58 PM
P_Adams's Avatar
It's best viewed from the front (so make sure the ebrake is set )
Although I'm quite sure that the Great State of Texas doesn't have the pot-hole problems we have in the Northeast, I'm sure there are more than enough parking lot curbs and other obstacles that can cause this.
Good luck
P
Old Mar 21, 2006 | 05:00 PM
Ross 2.0's Avatar
In a Junkyard near you.
It's a shame to see you may have thrown a lot of money away but I definately agree with P.
Old Mar 21, 2006 | 05:26 PM
haha no potholes! we have tons and crappy roads at that. well the rack needed to be replaced anyways it was leaking but it did cost a bundle and thanx again guys.
Old Mar 21, 2006 | 05:29 PM
Ross 2.0's Avatar
did you fix it? What did you find?
KingDakota12
May 22, 2011 06:33 PM
lildragon'07
13
Jun 2, 2010 08:31 AM
buzlink
18
Nov 7, 2006 07:04 AM
tom_zeke
14
Mar 20, 2006 08:16 PM
