twm itbs installed and now cel
Old Mar 21, 2006 | 11:06 AM
aziantegger10's Avatar
Default twm itbs installed and now cel
trying to get everything ready for tuning, cel is on and i jumped the connecter and found the following
code 3- map sensor
code 10 IAT - intake air temperature sensor
code 14 IAC (EACV) - idle air control valve
anyone know where i should begin troubleshooting?
Old Mar 21, 2006 | 05:24 PM
crv-techu's Avatar
Default Re: twm itbs installed and now cel (aziantegger10)
clear codes by removing 7.5a fuse under hood for 30sec. Then try again if it still has lights then check the plugs and wireing you may have mixed one of the wires up.
Old Mar 21, 2006 | 05:27 PM
v4lu3s's Avatar
RTFM
what engine management do you have>
Old Mar 23, 2006 | 09:39 AM
mastarolla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziantegger10 &raquo;</TD></TR><TR><TD CLASS="quote">trying to get everything ready for tuning, cel is on and i jumped the connecter and found the following
code 3- map sensor
anyone know where i should begin troubleshooting? </TD></TR></TABLE>
Check the IAT and IAC sensor plugs....ive swapped these on accident several times with my ITB setup. I believe the red and yellow wire plug is the IAT.
It is the same as v4lu3s said before me for the map sensor though. The manifold vacuum is the PITA when tuning ITB engines without adequate engine management....
Old Mar 26, 2006 | 09:44 AM
thanks for the help guys, it turned out the iat was bad, i swapped it and the light is out.
ooopseyesharted
18
Feb 18, 2009 03:17 PM
EKris
Oct 20, 2008 08:35 AM
axtran
May 12, 2006 08:28 PM
beedoublejay
Aug 21, 2005 03:28 PM
98JDM_Type_R
Sep 1, 2004 08:12 PM
