Pic request: Sidemount intercooler, installed
Im looking for pictures of sidemount intercoolers (dsm, supra, whatever) installed on, preferably, 96-00 civics but anything is good, I just need ideas of how people mounted it. The older topics dont have working pictures anymore
edit: should this be moved to app/cosmetic forum?
Modified by spoon_ferio at 3:04 PM 3/21/2006
i had a DSM sidemount, i think a 2nd gen, frontmounted on my 00 ej coupe. it worked damn well for like 4 months until i stepped it up to a johnnyracecar frontmount. i cut the stock IC piping down to 2" inlets and used a J pipe that actually ran in front if the IC and stuck out the front bumper a couple inches. this sexy piece has been dubbed the "front mount pipe" (i actually had just a front mount pipe there for a couple months when i had no IC at all, running directly across the front bumper). the whole setup with the side mount was pretty ghetto rigged since the IC itself was a bit too thick to fit comfortably in the front bumper and the inlets are positioned in a way that makes it nearly impossible to mount with the charge piping going the right directions. you'll probably have cut the **** out of your bumper but you can make it work.
i'll see if i can find a couple pictures tonight.
so i'm a day late...hope they help tho.
i cut a little of of the curve on the turbo side (bottom) of the ic, so it shoots pretty much right at the outlet of the turbo.
sorry, i bought a manifold, wg, dsm bov, and a dsm sidemount off of ebay for $95.. it all came together and I'm just not sure whether to use the DSM one that's coming or wait and get a front mount(which i was leaning towards)
Stewie
Welding / Fabrication
Aug 30, 2005 12:37 PM
hi mom
Jan 13, 2005 08:30 AM
boostincoupe
Jun 2, 2003 11:13 PM
