which arp headstud for ls-vtec?
Old Mar 20, 2006 | 11:07 PM
slayersluck's Avatar
Default which arp headstud for ls-vtec?
do you guys know which arp headstud application I'm suppose to get? is the GSR one okay? b18 block with b16 head. or if it was with gsr head? would it matter? thanks.
Old Mar 21, 2006 | 02:15 AM
rainforest's Avatar
Default Re: which arp headstud for ls-vtec? (slayersluck)
you will need gsr head studs. Not the head does not matter.
Old Mar 21, 2006 | 09:45 AM
Default Re: which arp headstud for ls-vtec? (rainforest)
anyone else? gsr head studs is the one?
Old Mar 21, 2006 | 11:17 AM
gsr it is
Old Mar 21, 2006 | 05:06 PM
boostedblkef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayersluck &raquo;</TD></TR><TR><TD CLASS="quote">anyone else? gsr head studs is the one?</TD></TR></TABLE>
GSR
Old Mar 21, 2006 | 05:32 PM
dfoxengr's Avatar
Default Re: which arp headstud for ls-vtec? (pitbullracer)
they have ones made for lsvtec.
Old Mar 22, 2006 | 12:19 AM
Old Mar 22, 2006 | 09:57 AM
tgreaves's Avatar
I just finished building my lsvtec and I used gsr studs..
Old Mar 22, 2006 | 04:20 PM
Default Re: which arp headstud for ls-vtec? (tgreaves)
kool thanks guy! what do you guys torque it to? w or w/o the LUBE. thanks.
Old Mar 22, 2006 | 04:58 PM
gsrallmotor's Avatar
I used gsr studs. You can use the lube or just dip the stud in some straight 30 weight oil. But do not torque the stud, just snug it by hand. You want to torque the 12 point nut. If you torque the stud you could crack your threads. You should tighten the cylinder head down in two steps. First step go to 22lbf. Then finish with 61lbf. Start with the Middle and work out going left to right. Doing it that way will give you a good seat for the gasket.
Old Mar 25, 2006 | 11:50 PM
Default Re: which arp headstud for ls-vtec? (gsrallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrallmotor &raquo;</TD></TR><TR><TD CLASS="quote">I used gsr studs. You can use the lube or just dip the stud in some straight 30 weight oil. But do not torque the stud, just snug it by hand. You want to torque the 12 point nut. If you torque the stud you could crack your threads. You should tighten the cylinder head down in two steps. First step go to 22lbf. Then finish with 61lbf. Start with the Middle and work out going left to right. Doing it that way will give you a good seat for the gasket.</TD></TR></TABLE>
My_EFsedan
Jan 17, 2012 10:06 PM
MrMug3n
Mar 6, 2009 02:42 PM
nebulight
Jul 4, 2006 03:58 PM
92gsrteg
Aug 12, 2005 02:41 AM
