what intake manifold should i go with my d16y8??
Old Mar 20, 2006 | 04:46 PM
ekVtecPower's Avatar
Default what intake manifold should i go with my d16y8??
i researched alot about wut i should get for my ex motor, but i dont know wut to purchase.. any ideas anyone?? plz thanks
Old Mar 20, 2006 | 04:52 PM
A-busive's Avatar
Default Re: what intake manifold should i go with my d16y8?? (ekVtecPower)
i made a post on this too, i got reply of skunk2,edelbrock and their was another one
Old Mar 20, 2006 | 04:53 PM
A-busive's Avatar
here u go https://honda-tech.com/zerothread?id=1561559
Old Mar 20, 2006 | 04:54 PM
schardbody's Avatar
no need to swap, the y8 is the best Dseries manifold.
Old Mar 20, 2006 | 04:56 PM
Voyage34's Avatar
generally the y8 is regarded as one of, if not the best oem D series IM. there isnt much in the way of aftermarket for us, the B series has much more. the only one i can think of off the top of my head is skunk2. if your motor is mostly stock, more than likely the gains will be minimal if anything at all. SMSP had a mild build d16a6 thread a little while back where on one set of runs the sk2 made 3.5ish more, and another run where it made just over 1 more. its up to you as to whether or not the extra 1-3hp is worth the couple hundred dollars for a new one. it seems to me there would be better/cheaper ways of making power.
https://honda-tech.com/zerothread?id=1493370
*edit* just read the other post and i completely forgot edelbrock. id expect similar gains with that vs sk2
Old Mar 20, 2006 | 05:07 PM
schardbody's Avatar
exactly, a cam swap would be a more wise choice. the y8 manifold is engineer to deliver enough air for the stock motor, until you bump the incoming air into the combustion chamber theres no need in swapping the IM. IMO
kajay1972
Nov 6, 2007 05:30 PM
borat rules
Oct 16, 2007 11:32 AM
marissio
17
Sep 22, 2004 07:04 PM
ritalin
18
Jun 2, 2004 02:48 PM
001020
Jan 25, 2004 09:57 PM
