Will a Si control arm fit on an Lx
Old Mar 20, 2006 | 04:05 PM
Themouse's Avatar
Default Will a Si control arm fit on an Lx
Can you swap them a 00 si control arm on a 97 lx
Old Mar 20, 2006 | 04:20 PM
professor poon's Avatar
Default Re: Will a Si control arm fit on an Lx (Themouse)
I have a similar question...
You want those LCAs so you car do a swaybar right?
Old Mar 20, 2006 | 06:37 PM
Themouse's Avatar
Default Re: Will a Si control arm fit on an Lx (professor poon)
the lca hold your wheel in the center and is a main support you can add a sway bar i'm pretty srue
Old Mar 20, 2006 | 06:53 PM
oh sorry I just realized how strangely I phrased that. I meant..."I would like to know that too." and then to you: "Is the reason you want the Si control arm so that you can use a swaybar?"
Old Mar 20, 2006 | 06:57 PM
fmrprojects's Avatar
yes you can
Old Mar 21, 2006 | 07:12 AM
D50boy's Avatar
Upper control arms swap just fine.
Lower control arms will fit but you will also need an SI shock fork and the longer bolt that connects those 2 parts together. The SI LCA is wider and made from stamped metal whereas the ones on your LX are cast and thinner.
kelsodeez
Jun 26, 2011 08:38 AM
superg6819
Oct 9, 2007 06:13 PM
AFTERZERO
Feb 7, 2006 07:52 PM
One Bad GeeSeeR
Jul 14, 2002 05:06 PM
HondaIntegraLS
Apr 3, 2002 05:11 PM
