94 civic dx....d15b swap questions
Old Mar 20, 2006 | 03:35 PM
hizroyalty's Avatar
Default 94 civic dx....d15b swap questions
well i just bought my first eg, and unfortunately the stock motor is showing low compression....
has 110 k on it and i relly dont feel like rebuilding cuz its not a very potent engine to begin with
ok so heres my questions....dont tell me to search ive been on here for hours looking and i cant find what i am lookin for
i need to know what i need(a parts list)to do this swap....
obviously the motor itself(d15b vtec from hmotors)
ill get the trans as well
but what ecu do i need??
and as far as wiring goes, from what ive read i can get a vtec subharness from rywire which i will have to wire into the ecu pins, but will plug right into the solenoid on the motor correct??then i just need to wire in the knock sensor??
my stock axles should work,right??
i dunno i am soo pissed i even have to do this and any help pointing me in the right direction will help...i am new to vtec in general, but i am sure with the right direction it shouldnt be a problem....ive found a lot of info on b series v tec swaps, but not on the d15
i need to get everything ready b4 i even start the swap, and need to have it done,up and running in a weekend....thanks in advance i appreciate it
Modified by hizroyalty at 4:58 PM 3/20/2006
Modified by hizroyalty at 5:14 PM 3/20/2006
Old Mar 20, 2006 | 04:31 PM
hizroyalty's Avatar
Default Re: 94 civic dx....d15b swap questions (hizroyalty)
well i think i have the wiring figured out....just not too sure abou tthe ecu, and axles
i am 99 percent sure my stock axles will work....just need the ecu question answered!!!thanks in advance
Old Mar 20, 2006 | 04:48 PM
schardbody's Avatar
the correct ecu to get is a p08, which is basically a p28 that runs 1wire o2, unless you wanna run a 4wire o2 then just use a p28. all 92-95 axles are the same, the only differance is abs/non abs. as for the knock sensor the D15b doesnt use one so dont worry about that. everything else is pretty much plug and play with the exception of wiring the vtec.
Old Mar 20, 2006 | 05:00 PM
1992HB's Avatar
Default Re: (schardbody)
vtec is prewired for that car only wire you need to run is to the main harness connector to wire up vtec soleniod, oil pressure switch.
Old Mar 20, 2006 | 05:03 PM
schardbody's Avatar
vtec is only prewired in the 92, not 94
Old Mar 20, 2006 | 05:07 PM
hizroyalty's Avatar
yeh i figured that out that its only in the 92's its prewired...kool so all i need to do is wire up the vtec,get a p28 ecu and i am good to go....sweet makes me feel a lot better about this....thanks for the help
Old Mar 20, 2006 | 05:08 PM
hizroyalty's Avatar
Default Re: (hizroyalty)
i mean po8...sorry....thanks again
Old Mar 20, 2006 | 05:09 PM
schardbody's Avatar
yep thats all you need. also if your car (i know nothing about the dx) uses a stock 1wire o2 sensor you will have to wire it for 4wire o2, but thats simple. if it uses a stock 4wire then everything is pnp with a p28. also, rywire makes a vtec adapter harness you can check out. http://www.rywire.com
purplerain11
Mar 27, 2013 06:47 AM
wrxya33
20
Dec 19, 2010 10:08 AM
Manny 77
Sep 30, 2009 10:30 PM
badassgixxer
Sep 3, 2008 11:07 AM
Accordboy27
Apr 3, 2007 03:58 AM
