JRSC BELT question!!! will this fit??????? HELP
Old Mar 20, 2006 | 01:39 PM
DeDonDeRosa's Avatar
Default JRSC BELT question!!! will this fit??????? HELP
ok well i got off JR website that the blower belt is 4pk620 is the belt number
i called like 20 differ parts places when i gave them that part number they all coverted it to a diff belt brand.
i gave them the 4pk620 and they gave me a Dayco belt number which is 5040248 but then right underneith that it says 4pk630 they said that, this is the correct belt. like i said b4 every place i called said that its basically the same belt and that it will fit. IS this correct will this fit on a 97 gsr 6lb psi ????? every parts store says that this is the conversion belt to the number i gave them. help
basically saying thats the interchange number
Old Mar 20, 2006 | 04:23 PM
Default Re: JRSC BELT question!!! will this fit??????? HELP (DeDonDeRosa)
anyone?
Old Mar 20, 2006 | 05:26 PM
crxrocks's Avatar
The 4 indicates the number of ribs of the belt and the 620 indicates the length. You could try the 630 and see if you can take the slack out of it.
Old Mar 20, 2006 | 05:38 PM
Default Re: (crxrocks)
but what im saying is that the 4pk620 supersedes to the dayco 5040248 and if u punch in 4pk630 that supercedes to that same number 5040248
Old Mar 21, 2006 | 03:33 AM
bump
Old Mar 21, 2006 | 04:34 AM
help
Old Mar 21, 2006 | 08:34 AM
anyone know
Old Mar 21, 2006 | 09:12 AM
i2un's Avatar
1mm = .04inches
4pk620 = 4 rib 620mm or 4 rib 24.8 inches
4pk630 = 4 rib 630mm or 4 rib 25.2 inches
The difference isn't enough to cause any problems, you could take the extra slack out with your tensioner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">
i gave them the 4pk620 and they gave me a Dayco belt number which is 5040248 but then right underneith that it says 4pk630 </TD></TR></TABLE>
The Dayco belt number 5040248 makes me think that it is 24.8 inches but Dayco must have rounded that to 630mm which is why the package also says 4pk630.
For future reference, convert the belt size your looking for into inches. It'll make things go much faster for the parts counter monkeys.
Old Mar 21, 2006 | 10:53 AM
rmcdaniels's Avatar
Default Re: JRSC BELT question!!! will this fit??????? HELP (Emiken)
Enter the inches (approximate) and the number of ribs, and it will give you the standard and metric part numbers of any belts that are close to what you are looking for.
http://www.mvreader.com/cgi-bi...1&l=n
Old Mar 21, 2006 | 11:00 AM
rmcdaniels's Avatar
Default Re: JRSC BELT question!!! will this fit??????? HELP (rmcdaniels)
Then put the part number in here:
http://www.amazon.com/gp/brows...81601
They are cheap, ship quickly, and have about everything in stock.
Old Mar 22, 2006 | 12:22 PM
anyone else???? what are some belts you bought dayco etc. let me know
Old Mar 23, 2006 | 04:33 AM
Old Mar 23, 2006 | 03:31 PM
i2un's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">anyone else???? what are some belts you bought dayco etc. let me know </TD></TR></TABLE>
I've tried bunches of belts. Whatever is available at my local parts stores. From Autozone mostly: Goodyear Gatorbacks, kelly springfield, dayco. From Napa they'll have Gates which is one of the brands Jackson used to swear by, but they seem to run smaller than most other brands. And straight from Jackson and sometimes rarely available at Kragen: Bando.
I most like the Gatorbacks, kelly, bando....but a belt is a belt and they seem to be fairly cheap anyhow.
Old Mar 24, 2006 | 06:02 AM
boosted94cx's Avatar
* B A N N E D *
5040248 4PK0630 24.80 0.54 4
Old Mar 24, 2006 | 07:30 AM
Default Re: (boosted94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">5040248 4PK0630 24.80 0.54 4
Old Mar 25, 2006 | 07:25 AM
Default Re: (DeDonDeRosa)
TO DA TOP
Old Mar 27, 2006 | 06:45 AM
OK now im hearing that the 5040248 belt wont work WTF what belt and number have u bought for a GSR with 6psi come on no one knows ??
Old Mar 27, 2006 | 08:30 AM
anyone?
Old Mar 28, 2006 | 05:29 AM
WHO USED WHAT BELT ?
Old Feb 17, 2012 | 10:09 PM
bigpunn421's Avatar
sorry to bump something so old but do you know of any site that converts inches to belt part numbers?
i installed a 630mm belt and it was too long for my jrsc setup. i needd a dayco part number for a 620mm belt or 24.4 or 24.5"
Old Feb 17, 2012 | 10:19 PM
Spawne32's Avatar
each company has their own unique interchange for belt sizes
http://www.gatespowerpro.com/Comerge...TOKEN=49863927
http://webcatalog.bando.co.jp/produc...ch/english/USA
http://www.accessdayco.com/Interchange.aspx
and duralast belts commonly go by just the number and ribs, so a duralast belt at autozone would be 620k4
http://www.autozone.com/autozone/par...er=165253_0_0_
Old Feb 17, 2012 | 10:24 PM
Spawne32's Avatar
if you were to get a gates the number you would want is K040245
http://www.accessdayco.com/Additiona...x?Part=5040248
Old Feb 19, 2012 | 05:54 PM
bigpunn421's Avatar
i found some 4pk620 belts online. i have 2 different 630mm belts and they are too long. my setup only makes 4-6psi with them. and belt is loose with tensioner all the way down. so i need a 620mm. its a b18c with jrsc big boost kit crank pulley. and either 3.8" s/c pulley or 4.0". thakns for replies tho
thanks for the links and good info. autozone is rare around me too. mostly advanced auto, pep boys, napa. so im limited
i have to find a car/vechile/something that has a 620mm belt stock. 8 rib or 4 rib or 12 rib.
Chase2
Nov 14, 2007 12:26 PM
00Luder
Jul 24, 2007 03:30 PM
escape2me
Jul 27, 2005 08:51 AM
kb58
Jun 22, 2003 07:17 AM
type Gendy
Mar 26, 2003 03:58 PM
