Is the Falkin Azenis 215 a good drag racing tire?
Old Mar 20, 2006 | 01:07 PM
Teamdiesel's Avatar
Default Is the Falkin Azenis 215 a good drag racing tire?
As the title says, are these tires any good on the drag strip at chopping off those 60ft times?
Old Mar 20, 2006 | 01:51 PM
RaceProfessor's Avatar
Default Re: Is the Falkin Azenis 215 a good drag racing tire? (Teamdiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamdiesel &raquo;</TD></TR><TR><TD CLASS="quote">As the title says, are these tires any good on the drag strip at chopping off those 60ft times?</TD></TR></TABLE>
It's marginally better than a regular all season tire but what differenciates drag radials and normal street radials is the sidewall stiffness on the street radial. Drag radials generally has softer sidewalls for traction purposes.
Old Mar 20, 2006 | 02:10 PM
b20turboic's Avatar
Default Re: Is the Falkin Azenis 215 a good drag racing tire? (RaceProfessor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote">It's marginally better than a regular all season tire but what differenciates drag radials and normal street radials is the sidewall stiffness on the street radial. Drag radials generally has softer sidewalls for traction purposes.</TD></TR></TABLE>
Perfect answer
Old Mar 24, 2006 | 08:33 AM
midnitesol's Avatar
you should go with the new azenis 615. really sticky
Old Mar 24, 2006 | 09:13 AM
gsrious's Avatar
Default Re: Is the Falkin Azenis 215 a good drag racing tire? (midnitesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol &raquo;</TD></TR><TR><TD CLASS="quote">you should go with the new azenis 615. really sticky </TD></TR></TABLE>damn noob... you opinion should be backed up with facts.
*sticky on the road course, yes.
**sticky on the drag strip, um yeah... but, not good.--&gt; too stiff of a side wall. hard rubber.==&gt; wheel hop or poor 0-60'
Old Mar 24, 2006 | 09:47 AM
ExospeedAMcrx's Avatar
azenis werent made for drag racing. its funny when i hear people say that they hav drag racing tires on all the time and they have azenis. haha.
FYI: Azenis are not DRAG racing tires no matter how the thread design and softer they are compared to regular tires.
Old Mar 24, 2006 | 10:23 AM
midnitesol's Avatar
Default Re: Is the Falkin Azenis 215 a good drag racing tire? (exospeedAMcrx)
i dont recall calling them a drag slick. i have DOT approved NT01 for the track. by the way the azenis pulled a 2.1 60 ft. time with a stock *** B16.
Old Mar 24, 2006 | 10:54 AM
sorry for the confusion, I was recalling other people say they are DRAG slicks. not your post.
2.1 60ft isnt that much diff from a reg radial tire. I've pulled a 1.98 60ft on bridgestone potenzas
Old Mar 24, 2006 | 11:13 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">sorry for the confusion, I was recalling other people say they are DRAG slicks. not your post.
2.1 60ft isnt that much diff from a reg radial tire. I've pulled a 1.98 60ft on bridgestone potenzas </TD></TR></TABLE>
yup yup... driver has a lot to do with it too...
i've pulled 1.9 60ft's with federals
Old Mar 24, 2006 | 01:07 PM
ya my setup was ghetto 1990s style too. hehe.
Solid bars on the rear, no springs or shocks at all. Fronts were cut Intrax springs. 89 CRX with an all motor D16A6. 1.98 60s
Old Mar 24, 2006 | 01:10 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">ya my setup was ghetto 1990s style too. hehe.
Solid bars on the rear, no springs or shocks at all. Fronts were cut Intrax springs. 89 CRX with an all motor D16A6. 1.98 60s </TD></TR></TABLE>
LOL with steelies up front??? hehe
mine was in a 94 RS... full weight LS-T
Old Mar 24, 2006 | 03:20 PM
95GLX's Avatar
I have been looking at different tires for a DOT style drag tire.
Right now, you want a sticky tire with a soft forgiving sidewall. You also want something light to reduce rotational weight.
BFGoodrich drag radials, 225/45-17's:
-purpose built, sticky, soft ss, heavy-23lbs!
-$140 each average shipped.
continental contiextreme 225/45-17:
-light, 20lbs, all season tire. good contact. $115
Toyo t1r or t1s: 225/45-17:
20.9 lbs, track tire, stiff sidewall. $135. can get soft.
Nitto 555r, not available in 225/45-17
nitto -nto1 225/45-17:
d.o.t. approved comp radial. 23 lbs. soft, again track tire, not drag. lot of surface area stick but no sidewall flex.
then there is the m&H drag radial!
There are other options out there. Take the weight for the stick or give a little stick to loose some weight.
I wish the bfgoodrich drag radials were lighter!
You can always let some air out of a regular "R" compuind street tire to induce some extra sidewall flex.
It all comes down to your budget and needs.
Modified by 95GLX at 1:11 AM 3/25/2006
Old Mar 25, 2006 | 01:13 AM
midnitesol's Avatar
thats fine. thats a good *** time for potenzas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake &raquo;</TD></TR><TR><TD CLASS="quote">
i've pulled 1.9 60ft's with federals </TD></TR></TABLE>
i agree, if you cant drive your car you'll never know what it could do.
Old Mar 25, 2006 | 01:20 AM
midnitesol's Avatar
thats fine. sweet time for potenzas.
i agree, you must know how to drive your car
Old Mar 25, 2006 | 01:23 AM
midnitesol's Avatar
Default Re: (SnoFlake)
also remember i was running a stock motor with i/h/e.
Old Mar 27, 2006 | 10:28 AM
Teamdiesel's Avatar
What about snow tires? They are light, have soft to the touch pegs, and have soft sidewalls. Those came on my car from japan and work quite well. Have not used them on trackbite though, how do you think they will perform there?
Old Mar 27, 2006 | 11:27 AM
95GLX's Avatar
Default Re: (Teamdiesel)
I ran on snow tires a few times. they are soft, too soft! Also, there is less of a contact patch to work with.
I spun and had to really work at launching. this with awd as well! The Kumho MX's have given me some 1.7 60's, on 18's!
Anthony
tpeezy
Apr 21, 2008 02:24 PM
1baddturbosi
Feb 6, 2008 05:45 PM
ej1252
Nov 21, 2007 09:26 AM
R THIS
Jul 31, 2003 10:01 AM
93EH6
20
May 2, 2003 05:37 PM
