should i get just 2 drag radial tires? or 4????
Old 10-12-2007, 06:36 PM
1baddturbosi's Avatar
Default should i get just 2 drag radial tires? or 4????
Would it be wise to get only 2? or invest in 4 drag radials, so then i can rotate when they start to wear???
I wanna get a BFG G-force radials!!!
Old 10-12-2007, 06:42 PM
been there done that
doood's Avatar
Default Re: should i get just 2 drag radial tires? or 4???? (1baddturbosi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddturbosi &raquo;</TD></TR><TR><TD CLASS="quote"> or invest in 4 drag radials, so then i can rotate when they start to wear???
that would be smart
Old 10-12-2007, 11:09 PM
turbolshatch's Avatar
Default Re: should i get just 2 drag radial tires? or 4???? (doood)
just get two
Old 10-13-2007, 01:58 AM
90sedan's Avatar
Default Re: should i get just 2 drag radial tires? or 4???? (turbolshatch)
Is this for your DD or for a weekend/track car?
But really in either case, all you need is two.
Old 10-13-2007, 03:54 AM
Default Re: should i get just 2 drag radial tires? or 4???? (90sedan)
thanks guys
Old 10-13-2007, 05:35 AM
.adam.'s Avatar
are you gonna get them oversized, if so i would only go with two, oversized radials on the back might look kinda goofy
Old 10-13-2007, 07:20 AM
mike93eh2's Avatar
uh just 2 LOL, unless you are AWD.
Old 01-24-2008, 08:09 PM
Tchleung's Avatar
Default Re: (mike93eh2)
I run 4 all around on my daily driver. 225/45R17 25" tall tire
This year I'll be running the same out the back, but up front will be 235/60R15 M&H bias plys, 25.4" tall tire. 15's up front, 17's in the rear lol.
If you're only ever going to use them at the track, then just get two and mount them on the lightest wheels you can find
Old 01-24-2008, 08:28 PM
i ♥ snails
quicksilver1689's Avatar
yeah that DA looks good, if your going to track it just get some real slicks, but for the road i would say 4 DR's would be nice to compensate for the wear.
Old 01-25-2008, 04:35 AM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (quicksilver1689)
LOL @ people suggesting running FOUR drag radials on a FWD Honda.
Here's a thought...run drag radials up front, and cheap all-season's in the rear.
When the drag radials wear out...REPLACE THEM with new drag radials!
They only last 3-5k miles anyways, why waste ~$250-300 on a pair by throwing them on the back to wear out with no real "usage" out of them?
Old 01-25-2008, 05:02 AM
sp00led's Avatar
Default Re: (boostincoupe)
I bought a cheap set of rota 15x7's for my DR. Put the radials up front and just ran some regular tires in the rear. I got a set of four so I at least had matching rims when I used them.
Old 01-25-2008, 05:27 AM
Tchleung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">They only last 3-5k miles anyways, why waste ~$250-300 on a pair by throwing them on the back to wear out with no real "usage" out of them? </TD></TR></TABLE>
They last ALOT longer then that when on the rears. I drove them for about 7000 miles and the rears were still brand new. The frotns on the otherhand had about 15% left
Old 01-25-2008, 05:50 AM
twkdCD595's Avatar
Default Re: (Tchleung)
2 for sure, I dont understand why you would want 4 in any situation with only 2 powered wheels needing them... drag radials wear far too quickly to be putting them all way around (even in back) when only needed up front. Put a normal tire on the back, DR's in front. Unless your just itching to blow twice as much money on tires than you need to.
Old 01-25-2008, 06:40 AM
Man U FTW
Schister66's Avatar
although 4 would look bad ***, there's no reason to get more than two. I just run my two on the front....
Old 01-25-2008, 06:53 AM
jewjew bean's Avatar
Default Re: (Schister66)
I'm sure bfg's weigh a lot more than regular all seasons
Old 01-25-2008, 07:36 AM
FATBOYeg6's Avatar
Default Re: (jewjew bean)
i don't know about everyone else, but i ran 4 on my last car. 98 coupe with an ls motor / gsr tranny. i loved the setup. i ran 2 for like a week, but i hated the way the car turned. so i put the other 2 i bought as back-ups on the rear. it was a totally different car! after about 4000 miles, i swapped front to rear and went another 4000 miles. it wasn't my dd, but i did drive it every night. if your strapped for cash, just get 2. if you can swing 4, why not?
Old 01-25-2008, 07:50 AM
GO GIANTS!
HondamanXxX's Avatar
Here's a thought...run drag radials up front, and cheap all-season's in the rear. </TD></TR></TABLE>
Old 01-25-2008, 08:25 AM
boostedeg302's Avatar
Default Re: (HondamanXxX)
4=bling bling factor
2=practicallity factor
Old 01-25-2008, 08:55 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">I run 4 all around on my daily driver. 225/45R17 25" tall tire
this DA looks awesome but as far as 4 drag radials on a DD i think they would wear down too quickly. i dont have the $$ for that. if you have a 400whp DD and need some drag radials up front for tractions issues then thats cool but all 4 just isnt really practical. my $.02
Old 01-25-2008, 02:55 PM
LeGeND4LiFe's Avatar
Are there any real handling or grip benefits in turns to running 4 DRs vs running 2 DRs and high performance street tires on the non driven wheels?
Old 01-25-2008, 04:12 PM
Tchleung's Avatar
All I know is she turns on a dime with teh DR on all 4. Because of it being a radial tire and a 45 series, there is very little sidewall flex
Old 01-29-2008, 04:18 PM
FATBOYeg6's Avatar
what he said. before i put the radials on the back, my car would understeer pretty bad on on-ramps. now, it just sticks. sure, 4 drag radials aren't practical, but they sure are fun!
Old 01-29-2008, 04:27 PM
Boner_Ben's Avatar
Default Re: (FATBOYeg6)
Why would you want to put a soft sidewall sticky tire on a non-drive wheel? I dont see whats bling about it, if I saw drag radials on the back wheels of a fwd car I would laugh.
Old 01-29-2008, 04:32 PM
Man U FTW
Schister66's Avatar
Default Re: (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want to put a soft sidewall sticky tire on a non-drive wheel? </TD></TR></TABLE>
I agree...and BFGs arent the cheapest tires on the market. I run the BFG's on the front of my GSR with Falken Ziex 512s on the back...it works just fine for the street
Old 01-29-2008, 06:12 PM
H.A.R.T B18C1EG6's Avatar
i run azenis all around and i use BFGs up front when they are needed
Quick Reply: should i get just 2 drag radial tires? or 4????
