What mounts do i get if im swapping in a B16A2 in 92 civic VX HB
do i keep them stock or do i get mounts for a b16a2 into 92 vx?
and what axels, halfshafts and shiftlinkage do i get for it?
You can use the stock mounts, or you can choice to upgrade to an aftermarket mount.
Axels, halfshaft, and shiftlinkage you need them for the B Series engine, stock ones will not work.
easiest route is go to http://www.hasport.com, you can get all the parts except maybe the halfshaft from there. I got my halfshaft from http://www.importautosalvage.com. If your VX is automatic, make sure you get the automatic-to-manual mount from Hasport.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com »</TD></TR><TR><TD CLASS="quote">You can use the stock mounts, or you can choice to upgrade to an aftermarket mount.
so it would work if i took it off the Si? like the axle, halfshaft and shiftlinkage?
from what i hear, because im doing a simular swap is you can use the mounts off an si, lot cheaper then going aftermarket too. hope this helped hit me up to let me nkow how yours went !
AdamITR
Nov 21, 2002 11:50 AM
