Speedometer not working!!
look under your hood, directly bleow your throttle body on the back of the transmission.. there will be a 3 wire plug in it.. remove the plug and inspect it..
usually they accumulate water over a period of time (Although they're not supposed to.. ) and the terminals will "rust" and will result in brekage and no VSS signal.. Check to make sure all contacts are clean and in good condition.. if not, you may be replacing the VSS and possibly the plug..
this would be the 9th time I've seen this happen..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug »</TD></TR><TR><TD CLASS="quote">dont have a GSR ecu nor the money....and i guess no IAB's</TD></TR></TABLE>
If you aren't running a P75, your IAB's won't function. No big deal really. Running a p28 shouldn't affect your speedometer.
In both cases (yours, and the original posters) I would check the VSS
frostcivic
May 30, 2006 09:35 PM
