JUMPING IDLE
Old Mar 20, 2006 | 10:43 AM
96greyek's Avatar
Default JUMPING IDLE
I SWAPPED A B16Z6 INTO MY 96 EK AND AM RUNNIG THE ECU THAT CAME WITH THE ENGINE AND WHEN HTE ENGINE IS COLD THE IDLE JUMPS UP AND DOWN TILL ITS WARM HAS ANY ONE DONE THIS SWap if so i would like to talk to them or if any one can help me there are a coulple wires on the iacv that if i hook up makes it even worse please help
Old Mar 20, 2006 | 10:48 AM
TylerB's Avatar
Default Re: JUMPING IDLE (96greyek)
Did you get the motor from a friend or a shop?
Do you know what ecu you've got?
Old Mar 20, 2006 | 11:09 AM
JDM B16A's Avatar
yea, I got the same problem. My idle would jump from 1.5 to 2.1 back to 1.5 and den back to 2.1 and it does this **** 20 times before it settles back to .75. I need some help on this too! I thinks it's because my ECU is chipped with a SKUNK2? My vtec kicks in at 5.9
Old Mar 20, 2006 | 01:26 PM
OAKLEY_K20Z1's Avatar
24.126.129.153
thats becuz vtec is kicking in yo at idle!!!
Old Mar 20, 2006 | 02:54 PM
d.maczko's Avatar
Default Re: (M4D-SPANKIN-VTEC)
check that your idle screw isnt loose,
this erratic idle was caused by a loose idle screw on my friend accord
good luck to ya
Old Mar 20, 2006 | 08:11 PM
JDM B16A's Avatar
I fix it. It was the idle screw. I had it on too much. I lower the thing and everything went baCk to normal!
Old Mar 21, 2006 | 01:09 PM
96greyek's Avatar
ILL TRY THAT OUT AND GET BACK TO YOU
AND ITS A P28 OBD1 ECU
I ONCE READ A POST THAT SOME ONE PLUGGED ONE OF THE HOLS IN THE THROTL BODY LIKE WHERE IT MEATS UP WITH THE AIR INTAKE, AND THAT FIXD THE PROB ANY IDEAS ON THAT????
Modified by 96greyek at 2:38 PM 3/21/2006
Old Mar 26, 2006 | 06:01 PM
96greyek's Avatar
STILL DOING IT
Old Mar 26, 2006 | 06:13 PM
Sketch_hs's Avatar
FITV is the cause
Old Mar 26, 2006 | 06:24 PM
96greyek's Avatar
whats that something to do with the fuel injectors????
Old Mar 26, 2006 | 06:35 PM
Sketch_hs's Avatar
please try searching
Fast Idle Thermo Valve
Old Mar 26, 2006 | 06:38 PM
96greyek's Avatar
Default Re: (Sketch_hs)
k thanks guy
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
downshift3r
Sep 30, 2013 06:34 AM
minner
Oct 8, 2006 01:30 PM
91 ef sedan
Dec 16, 2005 12:37 PM
97hb
Feb 4, 2003 10:24 AM
