Idle when decelerating
Old Jan 24, 2003 | 07:23 AM
97hb's Avatar
Default Idle when decelerating
My idle is normal except when I am coasting down to a stop. Doesn't matter if I am in netural or not. When coasting down from a stop I put it in neutural and coast down the idle will not got under 1500rpm. Right when I stop the idle will drop to normal. It happens on and off but has just started happening when it was very cold out. It only happens when I coast down to a stop. When I am stopped the idle will resume normally. Also I just installed a ACT hdss but don't think this has anything to do with it. Help me out guys
Old Jan 24, 2003 | 07:29 AM
92TypeR's Avatar
FSAE
Default Re: Idle when decelerating (97hb)
Mine has been hanging out around 1100 for the last few weeks, then after a couple seconds when stopped, will drop to normal idle. I blame the Skunk2 program for that...do you have a chipped ECU?
Old Jan 24, 2003 | 08:13 AM
Turtle's Avatar
Default Re: Idle when decelerating (92TypeR)
Mine does the same thing, I'm not worried one bit.
Old Jan 24, 2003 | 08:32 AM
migs's Avatar
Mine also does the same thing. I think its just cause the cars moving and the air is somehow getting into the airbox, more than normal.
Old Jan 24, 2003 | 08:34 AM
speedymon's Avatar
Default Re: Idle when decelerating (Migs)
I thought it had to do with fueling.
Old Jan 24, 2003 | 08:39 AM
Nuts's Avatar
Default Re: Idle when decelerating (speedymon)
same in my r, wonder if it has anything to do with the cold weather or aggressive driving (redlining...)?
Old Jan 24, 2003 | 08:41 AM
vtec.dc2's Avatar
i always thought thats the way it should be, rpm won't drop to normal idle until the car stops.
Old Jan 24, 2003 | 09:15 AM
97hb's Avatar
It never used to do this before. Just started happening 2 days ago. Also took it out a while ago and car was fully warmed up and just idleing at 2000. I popped the hood to make sure throttle cable was alright and I didn't touch anything and it went back to normal idleing(800rpm). Maybe the IACV???
Old Jan 24, 2003 | 09:18 AM
GRM Scott's Avatar
25 Year Member
Trust in your computers
Old Jan 24, 2003 | 10:20 AM
stRtypR25's Avatar
if its the iacv your CEL will come on with a code 14
Old Feb 4, 2003 | 10:21 AM
SamC's Avatar
Default Re: Idle when decelerating (stRtypR25)
hhm...when decelerating...my car's rpm will idle very low and actually stop the engine like there weren't any gas. anyone know what's wrong?
Old Feb 4, 2003 | 10:24 AM
Chris N's Avatar
Check the Fuel System section of the Helms manual. The answer is in there.
There's nothing wrong with what is going on, it is normal.
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
Fatty_1775
Aug 6, 2003 05:32 PM
tylerdurden
Apr 11, 2003 05:53 PM
97hb
Jan 24, 2003 11:12 AM
