Bore and Stroke
Old Mar 20, 2006 | 09:39 AM
EGhatch33's Avatar
Default Bore and Stroke
when a car has more torque than hp, is the bore bigger than the stroke? or other way around... can sumbody explain?
Old Mar 20, 2006 | 10:47 AM
strokedb16delsol's Avatar
Default Re: Bore and Stroke (EGhatch33)
stroke increases torque more than hp and bore increases hp more than torque either way you will see gains. shorter the stroke faster it will rev up making your peak power at a higher rpm. longer stroke revs slower but your peak power is there alot sooner. it all depends on what your using the car for. my b16 is stroked to a 1.7liter and its set perfect for road racing redlineing at 10,000 make sure ur valve train is adicuite.
Old Mar 20, 2006 | 11:37 AM
schardbody's Avatar
any increase in displacement will increase torque. the reason stroking increases it more is because it increases the displacement more.
_Endless_
Mar 29, 2003 04:38 AM
ActiveAero
Jan 18, 2002 04:03 AM
InfamousRS
Dec 5, 2001 08:59 PM
Milano95
Oct 3, 2001 06:33 PM
JM Performance
Jun 18, 2001 08:46 PM
