spot welded ported shroud????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboElements.com »</TD></TR><TR><TD CLASS="quote">There is a velocity stack welded to the inside of the GT4088R this is a Full-Race built car and Geoffs GT40 is the same way.
what do you mean?
</TD></TR></TABLE>what do you mean?
As far as I know they just have the velocity stack cut to fit without having to cut anything on the housing.
And there is no non-ported comp housing available for the GT4088R.
im not an engineer or something, but that little opening all around the velocity stack CANT be that great for performance, i mean if you wante to make full use of the stack, shouldnt it be sealed, or mated with the opening of the turbo???
just looks like an unfinished product or something
The outer area around the stack needs to be open to take advantage of anti surge compressor housings. The velocity stack cuts down on turbulence, and helps the midrange a bit.
no air goes into the turbo on the outside of the velocity stack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson »</TD></TR><TR><TD CLASS="quote">The outer area around the stack needs to be open to take advantage of anti surge compressor housings. The velocity stack cuts down on turbulence, and helps the midrange a bit. </TD></TR></TABLE>
well there are NUMORUS post about non-ported housings making more power than ported....so i guess that's pretty much the goal of this...so, yeah...i think there might be some gains to be had. pretty cool stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Race Geoff »</TD></TR><TR><TD CLASS="quote">the benefit from "deleting" it is not from the lack of the surge rung, the benefit comes from the fact that the air entering the compressor housing is a fully laminar flow, and its less of a pressure differential across the compressor wheel.</TD></TR></TABLE>
http://www.supraforums.com/for...87830
