LS in 94 civic
Old Mar 19, 2006 | 04:51 AM
PullinGeeees's Avatar
Default LS in 94 civic
ok I just swaped my LS in. It has A DC header,spec clutch,H22 T-body,H22injectors and a revteck intake.... Im putting a thermostat in it today. It runs cold of corse with no thermostate.... but it was running rich as ****. I know a cold motor runs a lil richer. Could the fact its running so cold be why its running so rich? or is this normal with h22injectors.... if so will it hurt it to let it run rich. I pulled the dipstick last nite and it smelled like fuel a lil but not bad... I dont wana fuel wash the bottom end. Any help would be nice thanx guys
pic taken during swap
Old Mar 19, 2006 | 06:08 AM
Soccerking3000's Avatar
Default Re: LS in 94 civic (PullinGeeees)
uhh are h22 injectors the same size as b18 injectors? i dont think they are you are gunna need some sort of fuel management such as hondata, crome, ect ect.
Old Mar 19, 2006 | 06:24 AM
90DAkid's Avatar
ur motor look cricked ^^
Old Mar 19, 2006 | 06:54 AM
Mr_ET's Avatar
Default Re: (wyte_civic)
if you look at the mounts its not even mounted in the engine bay
Old Mar 19, 2006 | 07:16 AM
usdmEHboy's Avatar
Default Re: (Mr_ET)
their messing with you ...i'm not positive but i don't think the h22 injectors are the same as b18
Old Mar 19, 2006 | 07:54 AM
SVOboy's Avatar
H22 are 345cc or something and B18 are 240cc, which means every pulse you're injecting like 50% more fuel than you need to.
Old Mar 19, 2006 | 08:10 AM
JeffBro's Avatar
Those injectors will work, but not with any stock ecu. you need hondata my friend.
Old Mar 19, 2006 | 12:27 PM
Default Re: LS in 94 civic (JeffBro)
thanx guys and if you look above the pic it said PIC TAKEN DURING INSTAL its not bolted up yet .... I got the temp up to normal now and its not as rich i think im guna through the stock ones back in it for now...... even with the t-body header and intake I should be fine right?
Old Mar 19, 2006 | 03:02 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">H22 are 345cc or something and B18 are 240cc, which means every pulse you're injecting like 50% more fuel than you need to.</TD></TR></TABLE>H22 injectors are low-impedance type while the B18b injectors are high-impedance. In order for the H22's to work properly, you will need to install a resistor box (from a Honda Accord, 91-under Civic, 93-under Integra). If you are just running a basic IHE setup, there is no need to have that high of injector size without anything controlling them.
Old Mar 20, 2006 | 06:37 AM
Default Re: (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">H22 injectors are low-impedance type while the B18b injectors are high-impedance. In order for the H22's to work properly, you will need to install a resistor box (from a Honda Accord, 91-under Civic, 93-under Integra). If you are just running a basic IHE setup, there is no need to have that high of injector size without anything controlling them.</TD></TR></TABLE>
Now see thats what I needed thanx bro. Im guna find some stock 1.8 injectors and drop those in thanx guys. oh and here its not sideways any more
TYPErCRX
May 22, 2007 07:36 PM
dat_flip
Sep 17, 2004 12:47 PM
13secondmonster
May 14, 2004 07:23 AM
suprajb
Nov 17, 2002 11:00 AM
Top_spec
Mar 17, 2002 08:16 PM
