Rod Bearing Notch?
Old Mar 18, 2006 | 07:45 PM
stinker504's Avatar
Default Rod Bearing Notch?
Does it matter if you have it all facing intake or exhaust side? I just installed my crower rods all facing the intake side. Just worried now that I read a post saying to install them facing the exhaust. I want to know if I have to take my entire motor apart now to swap it around.
Old Mar 18, 2006 | 08:46 PM
stinker504's Avatar
Bump............... Does it matter?
Old Mar 18, 2006 | 08:57 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
yes it does matter
all the tangs need to be on the exhaust side
not 100% sure why but i think it has to do with the direction of engine rotation, or maybe the oiling holes
Old Mar 19, 2006 | 04:19 AM
D@nnY's Avatar
they face the exhaust ...take them back out
Old Mar 19, 2006 | 07:34 AM
DaveF's Avatar
Default Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">
not 100% sure why but i think it has to do with the direction of engine rotation, or maybe the oiling holes</TD></TR></TABLE>
i need a better explanation than that.
a rod is a rod. the oil is going to get into it regurdless of whether its facing int. or exh. the crank spins so its nothing to do with the oil holes. the rods are not offset or anything like that.
can someone explain why it "really" matters.
Old Mar 19, 2006 | 07:50 AM
NJIN BUILDR's Avatar
Default Re: (Dturbocivic)
I'm with you.I don't think it matters.A small block chevy has the tangs facing both ways on the same journal.I've seen rods with one tang on one side in the rod and the other side in the cap.If the rod doesn't have an offset or piston oiling hole than I don't see why the location of the tangs in relation to the block matters.
Glenn
Old Mar 19, 2006 | 08:29 AM
Bailhatch's Avatar
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">I'm with you.I don't think it matters.A small block chevy has the tangs facing both ways on the same journal.I've seen rods with one tang on one side in the rod and the other side in the cap.If the rod doesn't have an offset or piston oiling hole than I don't see why the location of the tangs in relation to the block matters.
Glenn</TD></TR></TABLE>
exactly, I just said the same thing in this clone thread. https://honda-tech.com/zerothread?id=1563880 I wouldent put them in 'backwards' though. Its so easy not to, so why do it the other way?
Old Mar 19, 2006 | 08:34 AM
stinker504's Avatar
I just spent the last 4 hours taking my motor apart to just swap the damn rod around. I feel better knowing it's what honda does, but I still don't see why. Ohhh well, better safe than sorry.
Old Mar 21, 2006 | 02:48 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">exactly, I just said the same thing in this clone thread. https://honda-tech.com/zerothread?id=1563880 I wouldent put them in 'backwards' though. Its so easy not to, so why do it the other way?</TD></TR></TABLE>
w000t w0000t ...
so it really doesnt matter
the main caps on the other hand do matter which way they go on the block..
Old Mar 21, 2006 | 07:46 AM
Muckman's Avatar
Moderator in Chief
Default Re: (Bailhatch)
I dont think it matters either. Ive built a couple GSR motors and the first one didnt conform to the tangs facing the exhaust, and never any problems with that motor. However now I make sure they face the exhaust just in case. It cant hurt. Just make sure the tangs on both bearings are on the same side.
Old Mar 21, 2006 | 08:06 AM
g2turbo's Avatar
Default Re: (Muckman)
For some reason I remember both tangs on cap and rod (manley) being on opposite sides. It has been a few months though since assembly. Anyone else with manleys remember?
Old Mar 21, 2006 | 09:42 AM
Muckman's Avatar
Moderator in Chief
Default Re: (g2turbo)
Hmmm my Pauters were on the same side. But now you got me second guessing my memory.
Old Mar 21, 2006 | 09:47 AM
g2turbo's Avatar
I just checked my pics from assembly...
Looks like I had them correctly. You can see in the first rod/piston that the cap is laying respectively to place both tangs on same side.
Old Mar 21, 2006 | 02:51 PM
Muckman's Avatar
Moderator in Chief
Yup mine are both on the same, exhaust side too.
Old Mar 21, 2006 | 03:02 PM
EnzoSpeed's Avatar
I didn't even take notice of which way the tangs faced when I installed my Crowers. No problems yet after six months of hard boosting.
dennis
Feb 15, 2012 03:44 PM
pdiggitydogg
Feb 23, 2007 06:05 PM
pdiggitydogg
Feb 22, 2007 04:29 PM
Sketch_hs
Mar 18, 2006 07:16 PM
Chiovnidca
Apr 18, 2004 04:03 PM
