Won't stay on VTEC??? JDM ITR
Old Mar 18, 2006 | 01:27 PM
LvN's Avatar
LvN
Default Won't stay on VTEC??? JDM ITR
My setup:
99 JDM ITR head w/BC IV cams and BC valvetrain
Aem CAI
Mugen 4-1 replica header
crapped out 2.5 carsound cat
Stock 99 Jdm ITR bottom end
Toda Cam gears
generic clutch
ITR FW
00 Si B16 tranny
**Correction**
I just found out that everytime I smash on it right after shifting, the rpm will bounce like 1500 back. So whenever I take it to 8500, punch on the clutch, shift quickly, then smash the gas, the rpm will jump back to 5000. It used to stay up in vtec when I had it on stock ITR ecu.
Here's my dyno:
https://honda-tech.com/zerothread?id=1555348
Modified by blkcivicpn0i at 5:45 PM 3/18/2006
Old Mar 18, 2006 | 04:32 PM
JDMC-Kamel's Avatar
Default Re: Won't stay on VTEC??? JDM ITR (blkcivicpn0i)
what clutch and flwheel???
Old Mar 18, 2006 | 04:34 PM
LvN's Avatar
LvN
Default Re: Won't stay on VTEC??? JDM ITR (JDMC-Kamel)
generic clutch and ITR FW
Old Mar 18, 2006 | 04:43 PM
JDMC-Kamel's Avatar
clutch new or well used????
Old Mar 18, 2006 | 04:47 PM
LvN's Avatar
LvN
Well I just realized that it's not just on vtec, it actually is whenever I try to smash on the gas after I shift that it jumps back like 1500rpms. The clutch is well used, had it for over a year, 25k miles.
Old Mar 18, 2006 | 04:57 PM
JDMC-Kamel's Avatar
what is vtec set at??
usually it drops about 1500rpms or more
Old Mar 18, 2006 | 05:02 PM
LvN's Avatar
LvN
It's set at 5800.. but after I shift, it would go to 6000 on vtec then jump right to 5000.. So it loses power significantly.. For example, I can't chirp on going to 2nd, it just drops out of power and works its way up again.
Old Mar 18, 2006 | 07:11 PM
TSX TEX's Avatar
It could be that your clutch is slipping......I could be wrong
Old Mar 19, 2006 | 02:55 PM
LvN's Avatar
LvN
Default Re: Won't stay on VTEC??? JDM ITR (iGntSegRa)
Clutch problem?
Old Mar 19, 2006 | 04:47 PM
JDMC-Kamel's Avatar
ur clutch is slipping and its doing the rev jump right
LvN
Mar 20, 2006 12:45 PM
kay_animation
May 16, 2005 01:57 PM
GQ 05YellowEVO8
Aug 22, 2002 02:29 PM
21stCenturyDigitalBoy
Sep 3, 2001 10:36 AM
