Can I use 13" rims on my girlfriends '96 civic?
Old Mar 18, 2006 | 07:36 AM
DSM-Mark's Avatar
Default Can I use 13" rims on my girlfriends '96 civic?
I have a set of winter rims and tires sitting around from an old car. They are 155/80R13s mounted (obviously) on 13" steelies with a 4x100 bolt pattern. My question is, will these rims fit on the civic or will the front brake hardware interfere? Her stock rims are 14".
Thanks in advance!
Old Mar 18, 2006 | 07:46 AM
dewoine's Avatar
Default Re: Can I use 13" rims on my girlfriends '96 civic? (DSM-Mark)
sense here wheels are 14 i believe that an ex so i dont think they will fit around the rotors but im not sure
bump anyways
Old Mar 18, 2006 | 07:48 AM
RedStar101's Avatar
Default Re: Can I use 13" rims on my girlfriends '96 civic? (dewoine)
yes they will
Old Mar 18, 2006 | 08:52 AM
medside's Avatar
Default Re: Can I use 13" rims on my girlfriends '96 civic? (RedStar101)
13 in. wheels will fit, just make sure the offset is right. or your tires will stick out, haha. some autocrossers race with 13 in. wheels. and i have seen some vatos with 13 in. wheels also,
Old Mar 18, 2006 | 10:20 AM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSM-Mark &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of winter rims and tires sitting around from an old car. They are 155/80R13s mounted (obviously) on 13" steelies with a 4x100 bolt pattern. My question is, will these rims fit on the civic or will the front brake hardware interfere? Her stock rims are 14".
Thanks in advance!</TD></TR></TABLE>
Depends what kind of civic. I have a 98 DX hatch and I run 13s. I don't think you can with EXs though. Also not that those tires are about 3/4" smaller in diameter than stock. So you can expect your speedometer and odometer to overread by about 3%. They are very narrow tires.
THere is only really one way to check. Put one on, you should know instantly if you will have problems or not.
Cheers.
Old Mar 18, 2006 | 01:11 PM
egcivicb16's Avatar
they should
Old Mar 18, 2006 | 01:15 PM
roycivic92's Avatar
Default Re: (egcivicb16)
well i think alot of ricers think there racing rims,lighter but the only reason for them using 13 inch steelies is for there bad camber and cheap tires.
Old Mar 18, 2006 | 01:31 PM
Default Re: (roycivic92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roycivic92 &raquo;</TD></TR><TR><TD CLASS="quote">well i think alot of ricers think there racing rims,lighter but the only reason for them using 13 inch steelies is for there bad camber and cheap tires.
The guy wants to know if he can use these as winter tires. What the hell are you talking about?
Old Mar 18, 2006 | 09:39 PM
dewoine's Avatar
Default Re: (old man neri)
wtf damn i was a ricer for a whole year and didnt even know it
too bad i didnt have negative camber to complete the whole look
Old Mar 18, 2006 | 11:54 PM
el_toro_de_magnifico's Avatar
they will fit with the stock brakes. if the brakes are from a ctr or itr then no it wont.
Old Mar 19, 2006 | 09:29 AM
EeeJayEight's Avatar
Default Re: (el_toro_de_magnifico)
there is a lot of info getting thrown around here... but here is your answer:
if she is driving a ex model it will not fit... it diameter of the inner part is smaller than the caliper therefore it will not fit.. they other trim level will be ok since they use a smaller rotor allowing the caliper to sit with a smaller radius
Old Mar 19, 2006 | 09:35 AM
dewoine's Avatar
Default Re: (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">there is a lot of info getting thrown around here... but here is your answer:
if she is driving a ex model it will not fit... it diameter of the inner part is smaller than the caliper therefore it will not fit.. they other trim level will be ok since they use a smaller rotor allowing the caliper to sit with a smaller radius</TD></TR></TABLE>
thats what i thougt too becuase my 93 dx steelies will not fit on my homboys 93 ex
kamby
Honda Civic (2006 - 2015)
13
Aug 20, 2009 09:28 AM
CodyC142
Aug 6, 2006 02:50 PM
quinnrob
32
Apr 27, 2006 11:48 PM
baonest
Dec 10, 2004 07:15 PM
Pele
Aug 4, 2003 09:37 AM
