water leaking into car?
wassup guys i have a 91 integ LS and right now its raining where i live which is in OC california and i was wondering why is there water coming out from the foot area of the passengers side area? could it be that rain leaked into somewhere and is coming through the car? what could be some possibilities?
try looking on http://www.g2ic.com apparently they have an article on this problem..
also, look in this thread
https://honda-tech.com/zerothread?id=1451775
check your taillights water seal. mine corroded and then i had massive water leakage problems around my foot area and the passenger side foot area. smelled bad too.
check the links that lead to g2ic.com for the solutions. there could be two problems with your car.
1.) the seals on your wiper cowl may have gone bad.
2.) make sure the drain tube from your a/c accumulator is properly leading to the outside of the car.
all of these problems occur in the passenger side front and im very sure it's one of those problems.
carlooooo
Feb 13, 2007 12:35 PM
crxaddikt
Oct 28, 2002 02:35 PM
