handling 15s w/195/55/15 vs. 16's 205/45//16
Old Mar 17, 2006 | 06:16 PM
Baron55's Avatar
Default handling 15s w/195/55/15 vs. 16's 205/45//16
which of the wheel and tire combo would handle better?
Old Mar 17, 2006 | 06:40 PM
Sleepy_Red_hatch's Avatar
Default Re: handling 15s w/195/55/15 vs. 16's 205/45//16 (Baron55)
i dont know really all that much BUT i do know that if it was the same wheel, you would have 2 downsides upon acceleration:
-you have more rotational mass
-the mass is located further out from the pivot point (the axle) requiring more force to turn
Old Mar 17, 2006 | 06:47 PM
JThrasher79's Avatar
Default Re: handling 15s w/195/55/15 vs. 16's 205/45//16 (Sleepy_Red_hatch)
the wider tires with less sidewall flex
the 16s
Old Mar 18, 2006 | 03:25 AM
Baron55's Avatar
others...
Old Mar 18, 2006 | 06:12 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Obviously the 16" tire is going to handle better. Wider contact patch and shorter, less flexible sidewall.
Now of course a 15" sticky tire is going to handle better than a 16" crappy all season tire, but in general the 16" lower profile will be better.
Old Mar 18, 2006 | 06:55 AM
Reid's Avatar
Global Moderator
Which tyres are you referring to?
BTW, the skill level of the driver will play a far larger role than this particular detail of car setup. If you're concerned with such trivial details, I hope you're autocrossing or doing high performance driving events on a road course.
Old Mar 18, 2006 | 07:20 AM
nickG's Avatar
do they make azenis in 205/45 16???
i know they come in 205/50 15...
youre tire selection is more important than the actual size right now...
so id go w/ 15s...cheaper wheels and tires
Old Mar 18, 2006 | 08:32 AM
JETSPD1477's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Which tyres are you referring to?
BTW, the skill level of the driver will play a far larger role than this particular detail of car setup. If you're concerned with such trivial details, I hope you're autocrossing or doing high performance driving events on a road course. </TD></TR></TABLE>
Old Mar 18, 2006 | 09:09 AM
Doopreme's Avatar
Default Re: (JETSPD1477)
I think the Azenis RT615 only come in 215-45-16
Old Mar 18, 2006 | 09:28 AM
yee SERIOUS's Avatar
i had azenis rt615's in 205/40/16. i would go with the 16's over the 15's, unless you're gonna run a 15x7 wheels
Old Mar 18, 2006 | 01:56 PM
Baron55's Avatar
ok check this out, stock tire size is 195/55/15, if i go to 16 rims since i am adding 1 inch to the rim wouldnt i minus 1 inch of tire, and that would be 205/30/16? since 25mm=1 inch? i am just asking, i never looked into buying rims, i always had stock..
Old Mar 18, 2006 | 02:06 PM
nickG's Avatar
Default Re: (Baron55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">ok check this out, stock tire size is 195/55/15, if i go to 16 rims since i am adding 1 inch to the rim wouldnt i minus 1 inch of tire, and that would be 205/30/16? since 25mm=1 inch? i am just asking, i never looked into buying rims, i always had stock..</TD></TR></TABLE>
nope..
the second number is a ratio, not a measurment...
it is the ratio of the width of the tire to the height of the sidewall..so the larger the second number is, the taller the sidewall is...but it is not a direct measurment of the sidewall, unlike the first number which is a direct measurement of the width of the tire
Old Mar 18, 2006 | 04:51 PM
maxogsr's Avatar
Default Re: (nickG)
That funny guys cause I just post a tread that talk about the same size and tire brand... It's in the autocross section...
For DC2...Azenis rt615 = 205/40/16...215/45/16...225/50/16...
Depending on how much drop you got on your car... Right now, after all the anwser I had, the best way to go seems to be 205/40/16 or 215/45/16... The only thing is will the 215/45/16 will rub a bit under hard cornering...
Hope this help.... But go make a check a the other tread...there is good link for the conversion...
Old Mar 18, 2006 | 05:47 PM
Reid's Avatar
Global Moderator
Since you didn't list any track experience, I'm going to assume you don't have any.
If this is the case, don't worry about which tyre size is better. As a driver you won't be able to tell the difference. Just go with whatever is cheaper.
Old Mar 18, 2006 | 05:51 PM
92integraVTECgsr's Avatar
Default Re: (Reid)
i had 205/40-16 and now i have 195/55-15. the 16's handled a little better, but were heavier. the 15's are nice, but im going with 50 series tires next.
Eran
Nov 17, 2011 10:50 PM
drewbie
Apr 29, 2004 06:59 PM
ebelp
Feb 6, 2003 09:05 AM
j_ambrose
Dec 14, 2002 10:58 PM
GM Killer
Mar 18, 2002 07:04 AM
