turbo tuning low idle HELP!!
Old Mar 17, 2006 | 05:46 PM
exotik4doorcivic's Avatar
Default turbo tuning low idle HELP!!
i got these injectors used
i have a d16z6 with a 14b and dsm 450cc and vafc2
i cannot get my car beyond 700 rpm when idling
i have the % set at -38 across the board and changing it higher or lower doest affect my idle
the throttle postion is 98% 99%
someone please help
im not running a missing link or check valves, and when im in nuetral and press the gas there is no hesitation but when i drive and vacuum tries to go past 0 it wont it will bog/cut out
Modified by exotik4doorcivic at 7:38 PM 3/18/2006
Old Mar 17, 2006 | 07:40 PM
iBrandon's Avatar
Default Re: turbo tuning low idle HELP!! (exotik4doorcivic)
have you tried messing with the idle screw?
Old Mar 17, 2006 | 08:09 PM
Default Re: turbo tuning low idle HELP!! (iBrandon)
there is no idle screw the one inder the throttle body is gone but before i installed the injectors it ran fine
Old Mar 17, 2006 | 09:34 PM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">there is no idle screw the one inder the throttle body is gone but before i installed the injectors it ran fine</TD></TR></TABLE>
huh?
Old Mar 17, 2006 | 10:22 PM
D@nnY's Avatar
??huh
Old Mar 17, 2006 | 10:23 PM
D@nnY's Avatar
the in is 98% and out is set at 99%
why are you trying to set the idle with the vafc?
Old Mar 18, 2006 | 12:14 AM
no2unenolife's Avatar
any check engine lights?
Old Mar 18, 2006 | 02:40 AM
D@nnY's Avatar
Default Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">any check engine lights?</TD></TR></TABLE>
theres no check engine light for doofus operator
Old Mar 18, 2006 | 06:41 AM
Race Egr's Avatar
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">
theres no check engine light for doofus operator</TD></TR></TABLE>
haha
Old Mar 18, 2006 | 08:47 AM
VTC_CiViC's Avatar
Default Re: (D@nnY)
Some check engine lights would never shut off..
Old Mar 18, 2006 | 10:05 AM
Default Re: (VTC_CiViC)
all im trying to say is before i installed the injectors it idled fine, i set the correction -40% across the board on high cam and low cam
06 in 06 out
throttle position is 98% 99%
im not trying to raise or lower my idle with the vafc im trying to get my a/f correct to ensure im not dumping too much fuel into my engine or not enough
i just dont understand why before my idle was perfect and now it idles around 600-700
Old Mar 18, 2006 | 10:08 AM
Default Re: (exotik4doorcivic)
the screw i was talking about was the screw underneath the throttle body under the butterfly handle if you screw it in or out it will adjust your idle
Old Mar 18, 2006 | 02:37 PM
D@nnY's Avatar
no theres another screw on the top of the throttle body ..loosen it
Old Mar 18, 2006 | 05:53 PM
Default Re: (D@nnY)
i found the problem
one of the wires on the tps sensor was out so it wasnt reading throttle % therefore
dumping way too much fuel
i just took it for a drive and its insane im only running 6 lbs of boost too!
d16z6
14b turbo
dsm 450cc's
apexi vafc2
spearco intercooler 2 1/2 inch charge pipes
monza bov
msd ignition blaster 2
act stage 2 clutch, 12lb flywheel
b and m shifter
thermal r&d exhaust
i need to get a high flow cat
Crxdriver1989
Dec 19, 2017 01:28 AM
Toanz
Jun 23, 2008 03:57 PM
NAmodified
Dec 5, 2007 04:04 PM
redED9Si
Aug 21, 2005 06:58 PM
Dyzee
Oct 29, 2004 10:27 PM
