Hondata on a ob2 vehicle...........
Alright an s100 with boost option p28 on a 0b2 car. The car is throwing an SRS light and stays on solid, the check engine light is on using the jumper wire only flashes once for the 02. My 02s are brand new and it still comes on, I cant pull the airbag code cause its an ob2 port with an obd1 ecu. The scanner wont connect. Anyone out there with any ideas or advice?
Modified by Drkaccrd at 1:23 PM 3/18/2006
so using the jumper harness I will be able to retrieve CELS & SRS codes with a scanner? Cause thats the problem Im having right now. I have an OBD2 car with a OBD1 ECU scanners wont connect because of that.
Wait will that work still considering hondata already converted the P28 ports to OB2 female ends? If thats what the jumpers main purpose was then I guess Im SOL. There really is no way around it...
97ej6civic
Aug 14, 2009 03:46 PM
