Can a test pipe(not cat.) make car run REAl rich
Old Mar 17, 2006 | 12:38 PM
Kyle244R948's Avatar
Default Can a test pipe(not cat.) make car run REAl rich
Well i went to inspection today with my test pipe in and my Hc read 725 and CO% was 9.80. This is way high for the limit, which is 225 and 1.09 in the state of Delaware. I know the test pipe is causing this problem, but could that be all? I have no CEL either, since I wrapped the 02 sensor in foil. Before I went through I put a couple things of octane booster in the tank too see what that would but thast all. I am purchasing a Catalytic convertor this week so that will help out a lot but I waas just wondering if that number sounds right with no tuning done and with a full T1R exhaust and test pipe? Thanks a lot, Hope someone can help.
Old Mar 17, 2006 | 12:57 PM
s2kdre's Avatar
Default Re: Can a test pipe(not cat.) make car run REAl rich (neo_)
more exhaust flow will lean out a little.
Old Mar 17, 2006 | 01:08 PM
Chris F's Avatar
Default Re: Can a test pipe(not cat.) make car run REAl rich (Kyle244R948)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyle244R948 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot, Hope someone can help. </TD></TR></TABLE>
Try a new o2 sensor and make sure the car is nice and hot when you go. You're right, it's really rich, and probably shouldn't be that rich even without a cat.
Passing this test (illegally?) is one thing, but your car is pretty badly tuned.
I should go to emissions just for fun, before I take the license plate off of my car
skcivic4life
Oct 28, 2007 04:50 PM
loner714
Apr 13, 2007 01:50 PM
concept11253
Feb 19, 2006 09:51 PM
djay86
Feb 15, 2005 10:00 PM
LSVTEC408
Jun 21, 2002 10:51 PM
