01 gsr check engine light reset
Old Mar 17, 2006 | 12:35 PM
eas156's Avatar
Default 01 gsr check engine light reset
where is the reset located on a 01 gsr
Old Mar 17, 2006 | 12:42 PM
purplegsr's Avatar
Default Re: 01 gsr check engine light reset (eas156)
If you're talking about the Check Engine Light and you already pulled the code, you can reset it after you fix the problem by disconnecting the battery for a few minutes, disconnecting the ECU on the passenger side kickpanel, or pulling the fuse for the ECU.
If you are talking about the Maintenance Required Light that blinks and then lights up solid every 7500 miles, you need to look under the right side of your dash, just in front of your right knee. There is a square blue button on the edge of the plastic bottom of the dash that you need to press and hold in while turning the ignition switch on (without starting it). If you hold down the button, the light will go out.
Old Mar 17, 2006 | 12:43 PM
eas156's Avatar
Default Re: 01 gsr check engine light reset (purplegsr)
thankx
nicokpe
Sep 27, 2007 09:41 PM
PIC Performance
Jun 12, 2006 10:37 PM
escape2me
Jan 25, 2005 02:16 PM
under_psi
Aug 16, 2001 12:50 PM
sackdz
Jun 23, 2001 09:36 AM
