Help, best way to pull alternator out of EF hatch d-series
i remove the brake master and push it over the intake manifold slightly and then pull the alternator up where the brake master was. my prefered method as i dont have to jack the car up or snake it out.
SAVE YOURSELF THE TROUBLE AND THE TIME GOING THROUGH THE TOP. Do this jack up your car, remove the oilfilter. place something in the bottom so it won't spill all over the floor. Barely any oil will flow out anyway. Once you removed that. Unbolt the all bolts and belt holding the alternator in place. Then simply turn it until it finds is way out. I did this to mine and save a whole lot money switching to GEICO, lol. any questions?.....just ask.
This is actually my car, so thanx for the info guys. Now who wants to come over here and get this stupid *** rusted bolt off of the alternator bracket?
You take it out from the bottom. All you do is loosen the alternator to get to the mounting bracket bolts. You remove the mounting bracket that bolts to the block and that gives enough room to drop the alternator out. It's really simple.
Well, finally got the old alternator out, and the new one in. Now the only thing holding me back is getting the new one in the brackets. Right now it's being a bitch and not fitting, so I'm thinking that I'll have to file it down or something. Anyone else got any ideas?????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED7 »</TD></TR><TR><TD CLASS="quote">You take it out from the bottom. All you do is loosen the alternator to get to the mounting bracket bolts. You remove the mounting bracket that bolts to the block and that gives enough room to drop the alternator out. It's really simple.</TD></TR></TABLE>
You've already done it, but maybe next time you could do it the easy way
Wheel well lining and tire removed, alt. ready to make its ascension
*edit* View from the top
HU MAN CHU
May 7, 2006 09:53 PM
BLUE EH3
14
Dec 14, 2005 09:01 PM
89hondahatch
Nov 12, 2005 05:19 PM
Jeff
14
Oct 19, 2005 12:02 AM
b16_madman
Apr 26, 2005 08:19 PM
