Shift Light wiring?
Old Mar 17, 2006 | 07:08 AM
Mistermark's Avatar
Default Shift Light wiring?
my speedometer doesnt have a tach, but im thinking of making a custom red shift light in the cluster
just wondering where is the signal wire?
and would that be the power wire aswell?
and then id just ground it
Old Mar 17, 2006 | 07:54 AM
hatchi's Avatar
Default Re: Shift Light wiring? (Mistermark)
this is for autometer shift lite
black -ground
red - 12 v power
white- light illumination
green-tach signal wire
it is the blue wire on the dist i believe
Old Mar 17, 2006 | 08:04 AM
Mistermark's Avatar
thanks
my idea is to take one of the spaces on the cluster like the SRS light (since i dont have airbags anymore) and making the bulb, light up at redline basically w/o a tach.
would i need a relay?
for the power, signal and ground?
thanks again
Old Mar 17, 2006 | 09:36 AM
Mistermark's Avatar
bump
Old Mar 17, 2006 | 09:40 AM
dgmorr's Avatar
The blue wire is the rpm signal. You can't easily make a shift light without using some sort or relays or switches.
Old Mar 17, 2006 | 11:20 AM
Mistermark's Avatar
would this work? also id have a inline fuse going from the battery of course
so thats power and ground, and then one side from the blue wire of the dizzy (signal) to the bulb in the cluster
Old Mar 17, 2006 | 11:31 AM
IHateJDM's Avatar
Default Re: (Mistermark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistermark &raquo;</TD></TR><TR><TD CLASS="quote">thanks
thanks again</TD></TR></TABLE>
You'll need an rpm activated switch.
Old Mar 17, 2006 | 01:07 PM
Mistermark's Avatar
is it possible to make a rpm switch?
just wondering
and please dont say "just go out and buy one"
cuz im just asking
Old Mar 17, 2006 | 01:09 PM
IHateJDM's Avatar
I'm sure it is possible, but I don't know how. they aren't that expensive though.
Old Mar 17, 2006 | 01:19 PM
Mistermark's Avatar
hmm i wonder if a variable resistor or a potentiometer would do the trick. so it would close the circuit at a certain voltage, higher voltage = higher rpm
Old Mar 17, 2006 | 01:21 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistermark &raquo;</TD></TR><TR><TD CLASS="quote">hmm i wonder if a variable resistor or a potentiometer would do the trick. so it would close the circuit at a certain voltage, higher voltage = higher rpm</TD></TR></TABLE>
yeah, that would work if you can figure out what the exact voltage is in the tach wire when you're at redline.
Cln94EG1
Mar 23, 2008 01:28 PM
integrals1983
Jul 4, 2007 02:55 PM
Hatch It
Nov 19, 2004 07:50 PM
SiZ
Apr 11, 2003 02:32 PM
BeanRacer
Jan 1, 2002 01:28 PM
