how to tell if trans is LSD?
Old Mar 17, 2006 | 05:51 AM
97grnrs's Avatar
Default how to tell if trans is LSD?
i have a b16 sir trans. i heard some are lsd.. how can i tell? it came from h motors. the sticker to identify it is no longer there either..so i cant tell which model it is.
Old Mar 17, 2006 | 06:56 AM
Double Agent's Avatar
Default Re: how to tell if trans is LSD? (97grnrs)
Try putting an axle in each side. Turn one axle. If the other axle spins the same direction it's LSD, if it turns the oposite direction or not at all you got a one legger.
Old Mar 17, 2006 | 07:14 AM
civexturbo's Avatar
Look through the axle shaft holes. If you see a shaft going through it, it is non-lsd I think.
If it is open all the way through or you can't see through it, LSD.
Old Mar 19, 2006 | 04:44 PM
wisjdmhonda's Avatar
Default Re: (civexturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civexturbo &raquo;</TD></TR><TR><TD CLASS="quote">Look through the axle shaft holes. If you see a shaft going through it, it is non-lsd I think.
If it is open all the way through or you can't see through it, LSD.</TD></TR></TABLE>
you mean you can see through it, LSD.
Old Mar 19, 2006 | 06:53 PM
D.Dappa's Avatar
Default Re: (wisjdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">
you mean you can see through it, LSD.</TD></TR></TABLE>
this correct if you can see all the way through you have lsd
killrB
Dec 4, 2007 10:21 AM
deathofadam
30
Jun 15, 2007 05:13 AM
champLSinteg
May 24, 2007 08:11 AM
champLSinteg
May 22, 2007 11:38 AM
chrisJ
May 7, 2003 03:02 PM
