98 accord lights
Old Mar 16, 2006 | 09:01 PM
Aznxguy4life's Avatar
Default 98 accord lights
hi i have a 98 accord lx and i have a problem with my interior lights on my dash. On my cluster my 3 main gauges isn't on, my ac lights dont work and my clock light dont work. does anyone know where the problem is and how i can fix it?? i checked all my fuses and i changed all my bulbs so i think it should be a wire problem. this all happened when i changed my radio without using a wire harness and my friend cut my wires and it sparked when he cut the ground. so i dont know what to do now
Old Mar 16, 2006 | 09:11 PM
pro1342's Avatar
check your fuses again, underhood and underdash
Old Mar 16, 2006 | 10:44 PM
philadd's Avatar
Default Re: 98 accord lights (Aznxguy4life)
This is generally why manufacturers say to disconnect the battery before installation... so someone can't do something stupid like this, I mean, accidentally do something like this. Sparked when he cut the ground, huh? Sounds more like he cut a power and ground wire at the same time, and shorted it out with the wire cutters. Again, not a wise move.
Check fuses again, as mentioned. Otherwise, have fun tracing wires and hunting for burnt ones...
Old Mar 17, 2006 | 06:25 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: 98 accord lights (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">
Check fuses again, as mentioned. Otherwise, have fun tracing wires and hunting for burnt ones...</TD></TR></TABLE>
Old Mar 17, 2006 | 06:27 AM
WHiTETYPEs's Avatar
Default Re: 98 accord lights (-Bionic-)
1.) check fuses and make sure you stuck them in the right places
2.) yes check the wiring
3.) when you where changing your radio you could of shorted something out
4.)get a voltage meter for wires and test the wires
Old Mar 17, 2006 | 06:30 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aznxguy4life &raquo;</TD></TR><TR><TD CLASS="quote">this all happened when i changed my radio without using a wire harness and my friend cut my wires and it sparked when he cut the ground. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHiTE.TypE.S &raquo;</TD></TR><TR><TD CLASS="quote">when you where changing your radio you could of shorted something out
Hence, "it sparked"
Old Mar 17, 2006 | 08:08 AM
NAiL05's Avatar
Could be your ground. Might want to give your t-stat ground a check if those year accords have one.
Old Mar 17, 2006 | 11:24 AM
philadd's Avatar
Default Re: (NAiL05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">Could be your ground. Might want to give your t-stat ground a check if those year accords have one.</TD></TR></TABLE>
Are you sure you posted this in the right thread? :scratches head:
Old Mar 17, 2006 | 05:47 PM
allicedout's Avatar
Not 100% sure on this but i heard if the bulbs you put in don't light up take them out and put them back in 180 degrees from the way u pulled them out. apperently there is a Negative and Positive connector on the bulbs, its more then likely you have + with + and - with -. give it a try.
Old Mar 17, 2006 | 06:24 PM
H2290's Avatar
1. Why would someone cut factory wiring?
2. Use a wiring harness for radios so you can wire it in the house.
3. Using a wiring harness you will never have exposed wires in the car.
4. If you're dumb enough to cut factory wires disconnect the battery.
6. If he shorted out the radio wires the underhood fuse labeled RADIO should fix the problem.
7. There is also an ACC fuse which may have shorted.
8. Friends don't let friends ruin factory wiring.
Old Mar 18, 2006 | 02:51 AM
MauiWowwee's Avatar
^^^hahaha, i totally agree with your list. especially with no. 8.
Old Mar 18, 2006 | 05:04 AM
BLKFLSH's Avatar
Default Re: (MauiWowwee)
"Idiots with tools", and "cars". You gotta keep em separated. A little bad music humor.
Old Mar 18, 2006 | 02:20 PM
Default Re: (BLKFLSH)
well does anyone know where i can get the wires for my dash and stuff??
93_FSWAP
Sep 8, 2011 12:56 PM
JasonYo
Aug 16, 2009 06:32 PM
tbone587
Oct 9, 2006 06:11 PM
Aznxguy4life
Mar 9, 2006 05:06 PM
rice_classic
10
Feb 18, 2002 09:27 PM
