Transmission Problem
Wondering what I should do about my transmission
about a month ago I just about ran out of transmission fluid and just made it home in 5th gear becuz it wouldn't shift into any other gear and I didn't want to force it. I had a leak but since fixed it.
So when I got home I put fluid in it and it started working fine no problems what so ever except a really high pitch noise when I'm in 5th. It wasn't hard to shift into but it just keeps making this high pitch noise and when I'm in 5th gear long enough it kicks out of 5th and into neutral...
some of my friends said its enternal and others said that I should just flush the tranny and put new fluid in it (Honda tranny fluid).
so my question is what is the problem? what should I do? and if it is just a flush what is the exact name of the fluid and do I get it from the honda dealer or somewhere easier?
thanx alot for the help
Usually running GM Syncromesh is what people say to use and sometimes people lose grinds into gears, but as far as popping out of gear i think ur tranny is gonna take a dump on you soon bro
gm syncromesh is what i use... its the ****
as for the trans poping outa gear that dont sound like anything the syncromesh would fix... ive heard of this problem before but everyone inkow that had it just replaced the trans
if it pops out of gear it can be a few things Shift linkage worn or misadjusted, Pilot bushing worn , shift fork,lever and/or shaft is bent or worn,transmission bearings, worn synchroizers hubs or broken key, bell housing, not enough spring tension or detent springs, or excessive play in output shaft bottom line either remove and rebuild or start saving. Driving without fluid in the tranny is almost as bad as driving without oil how far u drive without fluid ?
once I could tell it was acting up I was already on my way home... so a couple miles and I wasn't forcing it or anything
this sux
I have a brand new hydro tranny never done a conversion from cable to hydro tho... how much would it be to have someone do it since I already have the tranny or how hard would it be to convert?
this sux I have a brand new hydro tranny never done a conversion from cable to hydro tho... how much would it be to have someone do it since I already have the tranny or how hard would it be to convert?
well if u have the knowledge u can try to search for some info on how to do the convertion i have never done it tho. take it to a shop if you don't know what ur doing it will be about 200-500
I did the swap myself and took the hydro off put the cable on but I've never dealed with trannies internals ... except the flywheel and clutch and even with the flywheel and clutch it was just putting it in... other than that I'm lost yeah lol thanx for the help thats not too bad I guess $200. $500... eh
ok well I'm gonna check some places out today and see what they say thanx for all the help I'll get back to u guys
B16Jacques
Sep 15, 2006 04:06 PM
