engine miss...help me read plugs!
Running a little rough around town. Engine kept stalling when I'd come to a complete stop. Pulled the plugs and this is what I found.
What do you think...I'm new to the "tuning" thing.....maybe pull some timing or add fuel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic »</TD></TR><TR><TD CLASS="quote">They look a little lean.
How'd that happen
I don't know...maybe I got some bad gas
How'd that happen
</TD></TR></TABLE>I don't know...maybe I got some bad gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">im ASSuming this is a joke?</TD></TR></TABLE>
nothing to joke about man
I was running on a basemap...dude said it was cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6tPoweredMx3 »</TD></TR><TR><TD CLASS="quote">meh, put them back in and up the boost
you might of broke pieces of your piston off and hit the spark plugs causing that one to be broken, exactly what my plug looked like when I did that.
repetitive watching of fast and the furious on your in car ice has overloaded your electrical system, causing you to mess up the injector pulses, run lean and detonate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">repetitive watching of fast and the furious on your in car ice has overloaded your electrical system, causing you to mess up the injector pulses, run lean and detonate. </TD></TR></TABLE>
That movie rocks
my fav
I called Autozone to get new plugs...they said they're special order only
Should I spray'em with some brake cleaner and put'em back in?
That movie rocks
my fav
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">i say put some rust remover on them </TD></TR></TABLE>
I think I'm gonna put some rustoleum on this time and jb weld them in to keep the water out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">turn the boost up to 25psi.</TD></TR></TABLE>
You mean turn the boost down to 25psi?
Actually it looks like a combination of running lean, and braking too hard. I've noticed a lot of times that when I brake really hard, my car tends to miss and stutter some. It's pretty noticable. I think it's the same with yours apparently. I havent found a fix yet though. I tried putting stiffer springs in the front, but it didnt really help. Best of luck to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT »</TD></TR><TR><TD CLASS="quote">I think I'm gonna put some rustoleum on this time and jb weld them in to keep the water out
You mean turn the boost down to 25psi?</TD></TR></TABLE>
i tihnk that would work too! awesome man
