broken lude costed me $900 to fix!!
Old Mar 16, 2006 | 03:03 PM
camil212's Avatar
Default broken lude costed me $900 to fix!!
Ok today I got my baby back from the shop. It all began with a strange rattling noise coming from the timing belt side of the valve cover, the noise would come on after 2k rpm, so realizing that it wasn't running well took it to my mechanic, he then call me he said he had to lift the engine from that side a little bit to open things up and find out what's going on, well the tensioner broke, timing belts were shreading and the worst of all a piece of the tensioner bolt broke inside. To conclude, 2 timing belts were replace water pump , new hydrolic tensioner which I know it sucks , cam seals cranks seal balancer gasket, new oil changed and finally a new valve cover gasket which it needed badly, it was free gift from honda for sending the wrong tensioner bolt and free installation from my mechanic. all of this costed me $900 I'm just hoping I don't get another expensive repair like this again for days to come
Old Mar 16, 2006 | 04:01 PM
Lewdin' Incognito's Avatar
Default Re: broken lude costed me $900 to fix!! (camil212)
Just one thing.....you only have 1 timing belt.
Old Mar 16, 2006 | 04:36 PM
The_Sober's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camil212 &raquo;</TD></TR><TR><TD CLASS="quote">
Ok today I got my baby back from the shop. It all began with a strange rattling noise coming from the timing belt side of the valve cover, the noise would come on after 2k rpm, so realizing that it wasn't running well took it to my mechanic, he then call me he said he had to lift the engine from that side a little bit to open things up and find out what's going on, well the tensioner broke, timing belts were shreading and the worst of all a piece of the tensioner bolt broke inside. To conclude, 2 timing belts were replace water pump , new hydrolic tensioner which I know it sucks , cam seals cranks seal balancer gasket, new oil changed and finally a new valve cover gasket which it needed badly, it was free gift from honda for sending the wrong tensioner bolt and free installation from my mechanic. all of this costed me $900 I'm just hoping I don't get another expensive repair like this again for days to come </TD></TR></TABLE>
repairs are expensive...spell-check is free
flipwhip's Avatar
Default Re: broken lude costed me $900 to fix!! (Lewdin' Incognito)
I bet he meant timing belt and balancer shaft belt.
Old Mar 16, 2006 | 06:21 PM
antballs420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camil212 &raquo;</TD></TR><TR><TD CLASS="quote">Ok today I got my baby back from the shop. It all began with a strange rattling noise coming from the timing belt side of the valve cover, the noise would come on after 2k rpm, so realizing that it wasn't running well took it to my mechanic, he then call me he said he had to lift the engine from that side a little bit to open things up and find out what's going on, well the tensioner broke, timing belts were shreading and the worst of all a piece of the tensioner bolt broke inside. To conclude, 2 timing belts were replace water pump , new hydrolic tensioner which I know it sucks , cam seals cranks seal balancer gasket, new oil changed and finally a new valve cover gasket which it needed badly, it was free gift from honda for sending the wrong tensioner bolt and free installation from my mechanic. all of this costed me $900 I'm just hoping I don't get another expensive repair like this again for days to come </TD></TR></TABLE>
was there a point?
Old Mar 16, 2006 | 07:16 PM
m.c.'s Avatar
Default Re: broken lude costed me $900 to fix!! (The_Sober)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober &raquo;</TD></TR><TR><TD CLASS="quote">repairs are expensive...spell-check is free </TD></TR></TABLE>
tu she
(spelling?)
Old Mar 16, 2006 | 09:43 PM
camil212's Avatar
Default Re: broken lude costed me $900 to fix!! (m.c.)
yes that's what I meant balancer shaft belt for the second belt.
Old Mar 16, 2006 | 11:18 PM
gamblezhang
Guest
Posts: n/a
my friend used to work to toyota...he did mine for 200$labor hehehe...plus the catalis converter change.(don't know how to spell)
Old Mar 17, 2006 | 04:54 AM
v4lu3s's Avatar
RTFM
how did it come out to $900?
Old Mar 17, 2006 | 05:43 AM
shutta's Avatar
if you have an autotensioner fail, will honda replace it with a manual tensioner if you ask them to?
Old Mar 17, 2006 | 07:22 AM
The Birdman's Avatar
Default Re: (shutta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">if you have an autotensioner fail, will honda replace it with a manual tensioner if you ask them to?</TD></TR></TABLE>
ha knowing honda they'll probably tell you to beat it
Old Mar 17, 2006 | 07:43 AM
The_Sober's Avatar
Default Re: (jd3jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverlude15 &raquo;</TD></TR><TR><TD CLASS="quote">I think it's pronounced touche.</TD></TR></TABLE>
actually, it's touché...don't forget the accent on the 'e'
Old Mar 17, 2006 | 09:07 AM
flight50's Avatar
Default Re: (silverlude15)
some of you guys can be so **** on here. you all knew what he was saying at least. i know you guys have seen alot worse on here. runs on, fragements, the whole nine. this isn't english class. its a forum to help others and get help or give suggestions and advice.
Old Mar 17, 2006 | 09:20 AM
The_Sober's Avatar
Default Re: (flight50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flight50 &raquo;</TD></TR><TR><TD CLASS="quote">some of you guys can be so **** on here. you all knew what he was saying at least. i know you guys have seen alot worse on here. runs on, fragements, the whole nine. this isn't english class. its a forum to help others and get help or give suggestions and advice.</TD></TR></TABLE>
thanks for the tip. I guess I'll stop screwing around now and answer his question...oh wait, that's right--he didn't ask a question.
Old Mar 17, 2006 | 10:34 AM
camil212's Avatar
Default Re: (The_Sober)
someone needs something sweet to calm the **** mood, like he said this isn't english class, just a forum we all prelude fanatics use to share information, stories and anything related to this car we all love. I apoligize if I in anyway insulted anyone with my english, English is my second language and I learned it about 13 years ago, I do speak 3 languages fluently Spanish, portugues and english. I also can communicate ok in Italian. If this thread is going to turn out into flames then moderator please Lock it. Thanks all for your opinions good and bad " I ain't mad at you"
Old Mar 17, 2006 | 10:48 AM
The_Sober's Avatar
Default Re: (camil212)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camil212 &raquo;</TD></TR><TR><TD CLASS="quote">someone needs something sweet to calm the **** mood, like he said this isn't english class, just a forum we all prelude fanatics use to share information, stories and anything related to this car we all love. I apoligize if I in anyway insulted anyone with my english, English is my second language and I learned it about 13 years ago, I do speak 3 languages fluently Spanish, portugues and english. I also can communicate ok in Italian. If this thread is going to turn out into flames then moderator please Lock it. Thanks all for your opinions good and bad " I ain't mad at you" </TD></TR></TABLE>
fair enough, just ball-busting.
emfman
Jan 12, 2024 12:50 PM
Cargo636
May 11, 2012 11:06 AM
77chev7777
14
Mar 12, 2012 05:09 PM
93CamaroLT1
10
Jul 18, 2006 06:50 PM
mvm42699
Apr 22, 2004 12:43 PM
