new dizzy, car won't start
Old Mar 16, 2006 | 02:26 PM
Slink2000's Avatar
Default new dizzy, car won't start
The other day my distributor went bad, had a code 9, so I replaced it with one from Distributor King. I installled it today and now my car won't start, it turns over but won't fire up and runs out of power as if the battery or alternator where bad, but if I have key and don't try to start it everything works lights, radio, etc. I cleaned up the spark plugs and checked all the wiring. Its a 91 civic si with a b16 1g. Anyone know what it could be?
I haven't check the timing, I don't have a timing light and don't know how to set the timing. On the back of the distributor, the part that connects with the cam there is a groove on one side does that mean anything?
Modified by Slink2000 at 3:36 PM 3/16/2006
Old Mar 16, 2006 | 03:19 PM
Slink2000's Avatar
Default Re: new dizzy, car won't start (Slink2000)
ttt. need help quick
Old Mar 16, 2006 | 03:25 PM
green91's Avatar
Even with the ignition timing completely off either way the car should start. Im guessing your plug wires are in the wrong order.
Old Mar 16, 2006 | 06:49 PM
Slink2000's Avatar
Default Re: (green91)
I triple checked the wires. Order goes like this right
4 3 2 1
3 4
1 2
Old Mar 16, 2006 | 08:46 PM
Slink2000's Avatar
bump
Old Mar 16, 2006 | 10:00 PM
SuperRacerTypeR's Avatar
u installed it backward, take out the dizzy and turn rotor 180 degrees and reinstall it and it will work, it happened to me b4
Old Mar 17, 2006 | 07:39 AM
Slink2000's Avatar
Default Re: new dizzy, car won't start (SuperRacerTypeR)
are you talking about the prong thing on the back of the dizzy that inserts into the cam?
Old Mar 17, 2006 | 12:49 PM
Slink2000's Avatar
ttt
Old Mar 17, 2006 | 02:59 PM
yes
Old Mar 17, 2006 | 03:03 PM
green91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slink2000 &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about the prong thing on the back of the dizzy that inserts into the cam?</TD></TR></TABLE>
No. The two teeth from the dizzy are different sizes and will only go into the cam one way. The rotor button inside of the dizzy can be installed 180* off, causing a no start situation.
julianbc2
Jun 8, 2011 02:52 PM
LMdb2teggy
May 24, 2010 12:29 PM
egtony
10
Sep 4, 2009 01:44 PM
RenzoDaPlayboi
Nov 3, 2006 10:01 PM
b18c-93
Jan 24, 2002 08:28 PM
