Where is the clutch located on an ls?
Old Mar 16, 2006 | 02:10 PM
I Like Hondas's Avatar
Default Where is the clutch located on an ls?
Im trying to find out what is wrong with my clutch the clutch is completly gone i press it and it sticks HELP????
Old Mar 16, 2006 | 02:30 PM
WhoDoYouThink's Avatar
Default Re: Where is the clutch located on an ls? (I Like Hondas)
back by the rear lower control arm under the muffler.
j/k gotta take off the tranny to see that.
Old Mar 16, 2006 | 02:31 PM
maxogsr's Avatar
Lost the pressure?
What year?
If 93 or lower, You problably broke the cable...
If higher 94+, Then check for spills under the hood...Follows the clutch fluid line up to the pump... You may have a bad line or you migth have blown the hydrolic...
That would be the first thing to check...
Needs more details from now after...
Old Mar 16, 2006 | 02:36 PM
maxogsr's Avatar
Default Re: Where is the clutch located on an ls? (2000turbogsr)
Ok, just saw the other tread....
under the muffler hein?!
hehe!
Old Mar 17, 2006 | 06:28 AM
duballstar's Avatar
Default Re: Where is the clutch located on an ls? (maxogsr)
maybe you need to bleed your clutch.. just like brakes.. the little nipple is on the tranny right belove your exhaust mani.
Old Mar 17, 2006 | 07:01 AM
solareclipseauto's Avatar
Default Re: Where is the clutch located on an ls? (duballstar)
check the clutch master cylinder (depending on the year)
teggy182's Avatar
we need to know whay year ls it is to help you
Old Mar 17, 2006 | 07:40 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Like Hondas &raquo;</TD></TR><TR><TD CLASS="quote">Im trying to find out what is wrong with my clutch the clutch is completly gone i press it and it sticks HELP????</TD></TR></TABLE>
If you don't know where your clutch is, it prolly not recommend you working on it to be honest. It has been answered though, it's in between your engine and trans, so that would be on your passenger side of the engine bay, and you can't see it with the transmission on, b/c the trans bellhousing encases the clutch assembly.
When you say your clutch sticks, does the clutch pedal stay on the floor and not return to it's normal position? or does the clutch not engage when you release the pedal - does it take a few seconds for the car to actually get into the next gear as your engines revs up (from you applying gas).
Slow Egg
11
Jun 26, 2017 11:25 PM
jhonda239
May 20, 2008 10:14 AM
RockyMtnTEG
Feb 24, 2007 11:34 AM
paul8ex
Apr 19, 2006 08:47 PM
De_tour
Feb 7, 2006 07:27 PM
