low idle
Old Mar 16, 2006 | 12:19 PM
epoch707's Avatar
Default low idle
after putting ngk plugs, wires, dist. cap, rotor, and p625 odessy battery my warm idle is very low, like 200 rpm, is this normal? How do I fix this?
Old Mar 16, 2006 | 12:28 PM
The Weather Man's Avatar
is that normal? hell no its not.
How does it drive?
Did you hook up the wires 1,3,4,2?
What wires are you using?
Hell, if it drives good, i'd keep it like that - especially how gas is going.
Old Mar 16, 2006 | 12:36 PM
epoch707's Avatar
Default Re: (The Weather Man)
it drives fine, but initial start up at a light or from a stop in reverse requires more gas to get it going
btw im using ngk wires, and i am pretty sure I hooked everything up right, I replaced the wires one at a time to be less confusing
Modified by epoch707 at 3:18 PM 3/16/2006
Old Mar 16, 2006 | 12:38 PM
limpmode's Avatar
i would bet it's 700rpm, since the guage does not really read below 500. i can't imagine it would hold 200 rpm's. i've never seen a car idle that low, but my guess is it would stall out. either way no 200 is not normal. if it is 700, you are fine.
Old Mar 16, 2006 | 04:37 PM
integra pride's Avatar
actually i have that problem too...after replacing spark plugs...sometimes the idle is too low n the car start shaking a little bit
Old Mar 16, 2006 | 07:28 PM
97 Sleeper's Avatar
Default Re: (integra pride)
yup got the same problem also after spark plug change i use the ngk V-Power ones
Old Mar 17, 2006 | 03:11 PM
delirious1520's Avatar
Default Re: (97 Sleeper)
hey guys, theres an idle screw on the top of the throttle body, its a flat head just let the car idle and adjust the screw but let the car warm up first so it is at operating temp not cold start.
Skybow388
Sep 18, 2012 07:51 AM
DEPintheCurve
Jul 18, 2012 03:17 PM
Tyson
Aug 7, 2008 06:10 PM
yee SERIOUS
11
Jul 27, 2003 11:39 AM
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
