HELP! which ecu tuning for turbo d16y7?
I am going to be turboing my d16y7 I upgraded to the y8 IM but my car is an OBD2 EK.....I am pretty new to the d series turbo, but staying away from the b for cost effectiveness.
I only plan on running 6-8psi on stock internals......lemme know what I will need.
thanks in advance.
thanks in advance.
OPTION 1)
Buy a OBD2 to OBD1 harness, walbro fuel pump, OBD1 p28 ecu, get it socketed, then go and get it tuned.
OPTION 2)
Buy an FMU 12:1, Missing link, fuel pump.
If you need any help let me know.
OPTION 2)
thanks for the suggestion.......I think I'm going the p28/jumper harness route. I picked up a modded p06 from Lee (ibiza) so now I just need the harness, fuel pump and a base map tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by utahbmx »</TD></TR><TR><TD CLASS="quote">OPTION 1)
OPTION 2)
If you need any help let me know.</TD></TR></TABLE>
Actually you don't really need the walbro fuel pump. Stock fuel pump should be just fine for the power goals you are trying to attain.
DAN
OPTION 2)
DAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron Burgandy »</TD></TR><TR><TD CLASS="quote">at what hp would I need to upgrade the fuel pump?</TD></TR></TABLE>
I would just do it. 99 bucks for added security.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">i made over 200 wheel on my stock d16z6 on stock fuel pump, you will be fine, id just go with obd2-obd1 conversion and run a p28 and tune with uberdata</TD></TR></TABLE>
how much boost were you pushing? I'll probably run Crome
p06 or p72 will both work for a d16y7
i use to run a p72 with hondata before on my 2000 d16y7 obd1 conversion
ur going to have to switch out ur iac to 2 wire as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage »</TD></TR><TR><TD CLASS="quote">p06 or p72 will both work for a d16y7
ur going to have to switch out ur iac to 2 wire as well</TD></TR></TABLE>
I have a y8 mainifold and throttle body
Teg4e
Jul 22, 2004 09:13 AM
