Do these look right? PIC
Old Mar 16, 2006 | 07:43 AM
BDogggUT34's Avatar
Default Do these look right? PIC
Do these look bent or is that how they are supposed to be? All they need is new bushings and should be good then right? Going on a 92 hatch. thanks for the help
Modified by BDogggUT34 at 8:56 AM 3/16/2006
Old Mar 16, 2006 | 08:16 AM
BDogggUT34's Avatar
Default Re: Do these look right? PIC (BDogggUT34)
blah! nevermind, found the answer on my second search!
https://honda-tech.com/zerothread?id=1180658
Old Mar 16, 2006 | 08:22 AM
dreww..'s Avatar
yes they should be curved, your ready to roll after new bushings, look into Energy Suspensions, they make a great product
Old Mar 16, 2006 | 08:25 AM
BDogggUT34's Avatar
Default Re: (dreww..)
thanks man, i looked at Jeg's and they are about $30. You think i can push them in myself? One more thing, when you get the bushings does it also come with the metal sleeve in the middle? Or do i reuse those?
Old Mar 16, 2006 | 08:28 AM
dreww..'s Avatar
Default Re: (BDogggUT34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDogggUT34 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man, i looked at Jeg's and they are about $30. You think i can push them in myself? One more thing, when you get the bushings does it also come with the metal sleeve in the middle? Or do i reuse those? </TD></TR></TABLE>
your new bushings will come with the insert, they arent the easiest in the world to get in but they come with directions to help you follow through to make it a smoother install
Old Mar 16, 2006 | 08:30 AM
BDogggUT34's Avatar
thanks! thats the plan then!
Old Mar 16, 2006 | 08:45 AM
nocturnaldragon's Avatar
Your best bet is to find someone with a press to put them in, easist way. otherwise they can be a pain in the butt. If there seized in there which I bet they will be I've seen people use air hammers (Be carefull not to damage the arms) and my personal favorite, carefully cutting them out with a sawzall and popping them out in pieces.
A press would be your best bet tho. The new ones if there like the old ones need to be pressed in as well.
The proplem your going to run into is not the rubber part but that metal outer ring is not going to want to come out without a fight.
Old Mar 16, 2006 | 08:51 AM
BDogggUT34's Avatar
Default Re: Do these look right? PIC (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Your best bet is to find someone with a press to put them in, easist way. otherwise they can be a pain in the butt. If there seized in there which I bet they will be I've seen people use air hammers (Be carefull not to damage the arms) and my personal favorite, carefully cutting them out with a sawzall and popping them out in pieces.
The proplem your going to run into is not the rubber part but that metal outer ring is not going to want to come out without a fight.</TD></TR></TABLE>
i've gotten pretty good with my dremel so hopefully i can work around things with that. i think i'm gonna start lookin around for someone with a press also. thanks for the heads up
Old Mar 16, 2006 | 08:53 AM
dreww..'s Avatar
haha yeah bro i completly forgot to look at your pics better...the old bushings suck to get out....we actually used an old socket that fit around around the bushing, heated them up, and just pounded the **** out of them with a hammer...a bit ghetto, but it was done carefully, and worked
ST4TUS
Jul 24, 2007 07:37 AM
2ltrgsr
Jun 27, 2006 08:08 AM
Wimpy.
Honda Motorcycles
13
Dec 9, 2005 03:04 PM
Old Man Quig
Apr 22, 2005 10:25 AM
Brand
Oct 14, 2004 07:21 PM
