'96-98 B20 into '93 EG???? Help please...
I am planning on buying a '96-98 B20b and swapping it into my 93 Eg hatch I already have a '95 B18B in the car now....it is usually sold as a Long block only...in which it comes with Motor, Intake Manifold, Exhaust Manifold, Injectors, Fuel Rail, Throttle body, Distributor.... no altenator though...(which alt. can be used) I have some knowlegde but would greatly appreciate some help with this swap, (Integra transmission can be used right)...thanks for all the information...plan on going CR/VTEC later...thanks again for all the help would like to hear from a few experienced honda gurus...
Re: '96-98 B20 into '93 EG???? Help please... (JDM_CivicEG6)
you must use the transmission and distributor already on the b18 in your car, use the b18 injectors aswell since they are OBD1 compliant. now, from what i have HEARD (no first hand experience) is that the intake manifold sits way too high up on the b20 so you would need to use the intake manifold from the b18. that should be about it.
Re: '96-98 B20 into '93 EG???? Help please... (Sleepy_Red_hatch)
So any B Series tranny will work with the B20....can i use the civic mounts or the B20 mounts
Modified by JDM_CivicEG6 at 3:38 PM 3/16/2006
95EG2
01-30-2010 04:22 AM
