check valves
Oh I get it lol. I just saw "no fuel management" and thought you were planning on installing the FMU soon. Thumb up to the ghetto setup.
Anywhere on the intake manifold should be a good spot for the check valves I would think? FPR, brake booster, etc... My buddy had a 5way check valve (so you can adjust) on his race car and he was running like 25psi lol, now that was ghetto.
Have you tried searching? I'm sure you could find some posts on it.
Hey man just put your check valves in between your map sensor and intake manifold. And make sure you can not blow back toward the map, and you got it.And you can also find these check valves at your local pet shop.Hope that helps.
