MINI ME VTEC
Old Mar 15, 2006 | 06:37 PM
jdm Ef-9's Avatar
Default MINI ME VTEC
i am working on my swap, and i just wanta pass on some info to ya, so ur swap can go as easy as mine did......using a d16y8 head.......3 things........
1st.
take out the oil doul & oring when ur at your block....inbetween cylinders 2 and 3 on intake side. because vtec requires more oil pressure. (if not, u will blow up motor.)
2nd
on distributor. round out holes on mounting brackets. you need to advance timing so ******* much. ur car will not run on stock setting....(i think its advanced 12 to 15.)
3rd
use a eg si timing belt......(ef's is too small and ek's is too big)
like i said, this is only to help anyone out....i did all of this and im runing a very low 15sec. 1/4 mile with built bottem end on NA tune d15b1........remember. only to help you guys out. im a jdm guy, not speed....thats why i have the turbo II 13b for that.....lol
thanks
matt
( also, u can use the EF'S intake manifold, PGMFI ( THE SI ) just use ek gasket.
Old Mar 15, 2006 | 06:48 PM
31flavorscivic's Avatar
Default Re: MINI ME VTEC (jdm Ef-9)
ty for the info will keep that in mind
Old Mar 15, 2006 | 06:53 PM
jdm Ef-9's Avatar
Default Re: MINI ME VTEC (31flavorscivic)
yup
sony224422
Sep 25, 2015 10:50 AM
miniR'Us
Apr 16, 2011 06:53 PM
EG_fan_59
Sep 25, 2008 01:46 PM
trecool44
May 31, 2007 09:38 AM
hazeleyes76
Nov 20, 2004 11:59 AM
