test pipe just showed up... 3 parts?
Old Mar 15, 2006 | 03:21 PM
EGhatch33's Avatar
Default test pipe just showed up... 3 parts?
ok so i ordered my omnipower test pipe and it came hooked together, but its 3 sections that slide apart. whats that for?
Old Mar 15, 2006 | 03:25 PM
SkRiBLaH's Avatar
Default Re: test pipe just showed up... 3 parts? (EGhatch33)
so you can adjust how long it needs to be
EGhatch33's Avatar
Default Re: test pipe just showed up... 3 parts? (SkRiBLaH)
ok thats what i thot... so when its adjusted do i weld it together?
Old Mar 15, 2006 | 03:35 PM
EGhatch33's Avatar
bump for help
Old Mar 15, 2006 | 04:01 PM
GetawayInMoscow's Avatar
I didn't weld mine.
Old Mar 15, 2006 | 04:03 PM
spoonracer84eg's Avatar
Default Re: test pipe just showed up... 3 parts? (GetawayInMoscow)
You dont weld it but im sure you could. Funny thing is I got my test pipe today also. Its skunk2....really nice.
Old Mar 15, 2006 | 04:14 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: test pipe just showed up... 3 parts? (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">You dont weld it but im sure you could. Funny thing is I got my test pipe today also. Its skunk2....really nice.</TD></TR></TABLE>
Yup. Just make sure fitment is snug, don't extend it to the point where it could slip apart with exhaust manifold/engine movement. It's happened to me on the track before. ...I was using a catback not designed for my car and so I had to adjust the testpipe too much. I thought it was snug, but I was using stock motor mounts at the time and the engine moved enough for it to pull the testpipe apart.
If you're using the correct catback/b-pipe, you shouldn't have to mess with the length of the testpipe too much.
Skunk2 and Omnipower testpipe are the same, BTW.
Old Mar 15, 2006 | 05:21 PM
koukidough's Avatar
after installation take it to a muffler shop so they can weld it for you. Shouldnt cost more than $15
Old Mar 15, 2006 | 06:34 PM
EGhatch33's Avatar
Default Re: (koukidough)
nahh i can weld it myself. aint no thang
Old Mar 15, 2006 | 06:35 PM
lazybrown187's Avatar
Default Re: (EGhatch33)
OR YOU COULD CLAMP IT
jdmisoverrated
Jan 31, 2008 07:54 AM
EGhatch33
May 1, 2006 09:37 PM
fjt
Nov 17, 2004 09:40 AM
SuicideSlide
10
Sep 23, 2004 05:58 AM
