oil temp gauge ques.
Old Mar 15, 2006 | 01:11 PM
2khb's Avatar
Default oil temp gauge ques.
I am thinking of installeing the sender for my autometer gauge to the factory location on the back of the block and am wondering if not using the factory sensor is going to affect anything. Or should I try hooking the factory one back up?
Old Mar 15, 2006 | 02:41 PM
rainforest's Avatar
Default Re: oil temp gauge ques. (2khb)
1. if you run it off the sender the temp won't be very accurate due to the fact its not submerged in oil and itjust running across it.
2. if you run no sending unit you will have a oil pressure light on and no vtec if you have it.
Old Mar 15, 2006 | 03:44 PM
NJIN BUILDR's Avatar
Default Re: oil temp gauge ques. (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">1. if you run it off the sender the temp won't be very accurate due to the fact its not submerged in oil and itjust running across it.
2. if you run no sending unit you will have a oil pressure light on and no vtec if you have it.</TD></TR></TABLE>
LIke he said...Oil temp sensor needs to be in the pan.
ActiveAero
21
Jan 29, 2007 12:53 AM
Sassafrass
17
Dec 14, 2006 02:10 PM
turbozc2001
22
Jul 10, 2004 10:38 AM
onyx00
May 14, 2003 06:22 AM
2kgs-R
Apr 4, 2002 05:37 PM
