Will a stock hood work with EFB1 mounts???
Old Mar 15, 2006 | 01:00 PM
b.d.racing's Avatar
Default Will a stock hood work with EFB1 mounts???
I've seen a few stock hoods with b series swaps and was wondering if it would work for me? I have a B18C5 and Hasport EFB1 mounts. Any way I can get the stock hood to work?
Old Mar 15, 2006 | 01:10 PM
89hatcher's Avatar
I'm pretty sure that the engine will clear the hood...or you might have to prop the hood with washers a little for it to clear...i have EFB1 mounts too and my hood cleared my b18 LS motor
Old Mar 15, 2006 | 01:18 PM
b18_crx's Avatar
Default Re: Will a stock hood work with EFB1 mounts??? (b.d.racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.d.racing &raquo;</TD></TR><TR><TD CLASS="quote">I've seen a few stock hoods with b series swaps and was wondering if it would work for me? I have a B18C5 and Hasport EFB1 mounts. Any way I can get the stock hood to work?</TD></TR></TABLE>
hmmmm me want answer too
Old Mar 15, 2006 | 01:23 PM
drachir's Avatar
From experience, I know that the EFB2 ones won't work. My valve cover lost some paint due to those mounts.
If the EFB1 mounts are anything like the EFB2 ones (I'm 99% sure they're the same) then you will have problems.
VIS makes a siR style CF hood that will clear. The middle section goes up instead of down.
Old Mar 15, 2006 | 01:37 PM
crxnj's Avatar
Default Re: (drachir)
My old car had a lsvtec and I had to cut the webbing under the hood,,But with the B16a it fits fine..
Old Mar 15, 2006 | 06:04 PM
b.d.racing's Avatar
Default Re: (Mr.speaker)
I don't mind cutting the webbing underneath. Not only will it keep the stock look but its way cheaper.
Old Mar 16, 2006 | 05:55 AM
b.d.racing's Avatar
Default Re: (b.d.racing)
Hmmmmm I'm thinking of getting a hood today to try out. I hope it works. I'll let you guys know.
Old Mar 16, 2006 | 04:33 PM
b.d.racing's Avatar
Didn't get that hood. Decided to wait for a definite answer from someone with efb1 mounts.
Old Mar 18, 2006 | 06:30 AM
civicandy's Avatar
my b16 valve cover rubs my hood, with hasport mounts. i'm pretty sure they are the efb1 mounts. what is the difference between the 2 mounts?
Old Mar 18, 2006 | 06:45 AM
b.d.racing's Avatar
Default Re: Will a stock hood work with EFB1 mounts??? (civicandy)
Do b16's and B18's sit the same height?
Old Mar 18, 2006 | 07:00 AM
civicandy's Avatar
i guess i thought they did. i was assuming the efb2 mounts were for hydraulic trannys, and efb1's were for cable trannys. anybody know if the zc hood clears the valve cover?
Old Mar 18, 2006 | 07:11 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.d.racing &raquo;</TD></TR><TR><TD CLASS="quote">Do b16's and B18's sit the same height?</TD></TR></TABLE>
No..B18vtec motors are taller ..And the deck height of the B18a/b/c block is taller then b16a motors..
Old Mar 18, 2006 | 09:03 AM
civicandy's Avatar
Default Re: Will a stock hood work with EFB1 mounts??? (Mr.speaker)
so the b18 mounts must place the engine lower than the b16?
Old Mar 18, 2006 | 09:10 AM
b.d.racing's Avatar
Hmmm, me would like to know also. I want to buy a stock hood and cut out the guts but I'm not gonna do it if it won't work.
Old Mar 18, 2006 | 09:24 AM
civicandy's Avatar
i would check with hasport. i'm sure they know
Old Mar 18, 2006 | 02:06 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">so the b18 mounts must place the engine lower than the b16?</TD></TR></TABLE>
No,they dont. Its all the same
94CoupeNY
17
Jan 25, 2013 05:14 PM
Trung Nguyen
18
Jun 15, 2010 02:29 PM
jtm509
Apr 5, 2010 09:17 AM
88'CRXsi
Mar 2, 2008 08:21 AM
Flite
Dec 16, 2006 12:25 PM
